I have seen many positive comments about this machine on this forum that I am begining to think that the problems I have with it are of my own doing. They are as follows
1. If I create a playlist from a recorded tv broadcast (ie a film where I wish to remove the adverts) and then write (dub) this to a dvd then the audio and video slowly drift out of sync. I have tried dubbing using the JUST feature and also Manual but neither makes a difference. About an hour into the dubbed copy the audio is almost 1 second behind the video.
2. If I copy a DVD on the PC it will not play on the JVC (error Unreadable Disc, Check Disc). I have tried DVD X Copy, CLoneDVD and DVD Cloner II. The copies (which you are permitted to do for back-up purposes) will play on a 3 year old Sharp Player and a PS2 so the copies are ok. I can not copy/backup the DVD using the JVC as it does not allow the copying of pre-recorded discs.
3. Similar to 2 when I try to play a "home movie" dvd created with Professional software the player will not play the discs.
During all my experiments I have tried 3 different manufacturers of DVD-r and DVD-RW discs. All will play on other players, just not the JVC.
The only thing that I have noticed in the instructions is that (on page 7 under Unplayable Discs) it states that it will not play discs recorded in UDF format. If I knew what that was and what software to use then it may help.
I am prepared to believe that it is my fault, or I have a rogue machine, but any suggestions or advice is welcome.
JVC if you are reading this then your Customer Support sucks. I have emailed 3 times in two months to the address on your web site and never even had an aknowledgement.
Results 1 to 1 of 1
Thread: JVC DR MH30S
VCR Comparison: JVC SR-W5U vs JVC SR-V101US
By robjv1 in forum RestorationReplies: 16Last Post: 22nd Apr 2010, 17:38 -
jvc dr-mh30s problema hd
By senateur in forum DVD & Blu-ray RecordersReplies: 0Last Post: 11th Nov 2009, 06:22 -
JVC SR-MV55US - Users with Experience with JVC Professional S-VHS/DVD Decks
By DeXeSs in forum DVD & Blu-ray RecordersReplies: 6Last Post: 21st Aug 2008, 15:23 -
Should I BUY the Canon HG10, JVC GZ HD7 or JVC GR HD1 ??????
By thecuban in forum Camcorders (DV/HDV/AVCHD)Replies: 6Last Post: 27th Dec 2007, 12:40 -
JVC DR-MH30S DVD-RW "No Disc" error
By snook001 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Sep 2007, 13:50
