VideoHelp.com Forum
  1. Member ViRaL1's Avatar
    I'm working on an old Packard Hell PC with a 1.2GB hard drive in it. It also had a 4.3 but I removed that. It has EZ-BIOS installed and it seems to be screwing up my fresh Win98 install. Any tips on getting rid of it. I'd think the computer (it's a P133) should be able to handle a 1.2GB drive on its own.
    TIA
    Nothing can stop me now, 'cause I don't care anymore.
  2. Member ViRaL1's Avatar
    NM, found it. I don't know why I didn't think of this earlier.
    FDISK /MBR
  3. Hello Ladies stiltman's Avatar
    You can also do
    fdisk /mbr .... lower case
    Originally Posted by jagabo
  4. Banned
    Are you sure?
    I think to remove EZBIOS you have to insert and boot to the EZBIOS disk and select "Remove" or "Uninstall" EZBIOS. It writes to BIOS, not to the drive.
    From way back when I screwed up and used it, for over 32 gig (with a 45 gig drive), about 5 years ago, and the tech told me you cannot read the drive without EZBIOS, I assumed you could not do an fdisk /mbr. That ain't gonna change the parameters to what the drive maker says it should be. ie, Cylinders, Heads, Sectors, etc.
    Cheers,
    George
  5. Member ViRaL1's Avatar
    Well, it worked. Granted, it was only a 1.2GB drive. I'm not even sure why it had EZ-BIOS on there in the first place, but it was keeping the OS from loading. I was getting an error asking for the location of COMMAND.COM. fdisk /mbr did the trick. Had it been a drive that was too large for the BIOS that probably wouldn't have helped.
  6. Hello Ladies stiltman's Avatar
    Yep, just do a search on "int 13 mbr"
    I remember that one from an interview i did about 10 years ago...missed it
  1. Bios malfuncitoning
    By Illusionist in forum Computer
    Last Post: 23rd Dec 2009, 19:25
  2. BIOS version
    By A Traveller in forum Computer
    Last Post: 25th Oct 2009, 08:56
  3. Can't get to BIOS
    By videocheez in forum Computer
    Last Post: 31st Aug 2008, 21:23
  4. ACPI in bios - on or off?
    By kenmo in forum Linux
    Last Post: 15th Apr 2008, 07:23
  5. BIOS Problem
    By Nitro89 in forum Computer
    Last Post: 16th Jan 2008, 10:38
