VideoHelp.com Forum
  1. I have been looking on numerous websites on the external subtitle issue (Including this one) but I can't seem to create a straight answer. Here's what Ive done so far:
    I got the latest firmware for my Philips DVP642/37 player (Ver. 1109), I am trying to burn my movie files (DIVX or XVID) with Nero Express using data format. I am using 4x DVD-R Ridata discs when burning my files and I have tried burning my movie files with the .sub & .idx together and separate, but I can not get the subtitles to work. The files are the exact same name as the movie file. (Example: movie.avi, movie.sub & movie. idx) When I go to the DISC MENU option on my dvd player, it shows the movie file and another movie file of the same name. (Shows them as MPEG4 & MPEG3 files) I tried playing both movie files, but none show subtitles. I tried using the SUBTITLE button while selecting each file in the DISC MENU screen, but that does not work either. Can someone tell me a definitive way how to do this? Its like all I find are opinions and no clear cut answer.
    Use srt text subtitles instead. Download from www.extratitles.to or convert the sub/idx to srt with subrip or vobsub.
  3. Originally Posted by Baldrick
    Sorry if this is a bother, but would you be so kind as to give a quick example on how to convert my .sub & .idx files into .srt files with these tools?
  4. Banned
    Load .idx file with SubRip, run OCR with it, save as .srt, done.
  1. Remote for Philips DVP642
    By Melina in forum DVD & Blu-ray Players
    Last Post: 10th Jun 2010, 21:54
  2. Philips DVP642 finally died...
    By Krispy Kritter in forum DVD & Blu-ray Players
    Last Post: 3rd Feb 2009, 13:06
  3. PHILIPS DVP642... how do I upgrade the firmware?
    By mummer43 in forum DVD & Blu-ray Players
    Last Post: 14th Jan 2009, 18:45
  4. Philips DVP642 DivX subtitles. WORK!!!
    By shrybouski in forum DVD & Blu-ray Players
    Last Post: 7th Aug 2007, 14:06
  5. Output resolution for Philips DVP642
    By cheerful in forum DVD & Blu-ray Players
    Last Post: 2nd Aug 2007, 23:41
