I have read till my eyes are bleeding. I have direct tv with tivo as well as other units in the house without tivo. Can I use an ATI all in wonder to get the signal to my PC then record shows to the pc then to DVD? All this hacking the tivo aint gonna happen so I'm trying to find an easier way.
Results 1 to 15 of 15
Thread: Direct tv to pc...Again
Hello,
Yeah just hook the audio/video out cables to the audio/video in cables as you would a vcr. Then just record as normal.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
No way it's that easy! Will I have a good picture when I record to DVD on my set top player?
WOW
No better than what you see directly on your TV, most likey a little bit fuzzier. You will lose 1) HDTV resolution and 2) DD5.1 surround audio.
hiro
Hello,Originally Posted by hsugawar
Ditto - It's an analoge capture. That's why people hack their tivos to get the digital files to the harddrive.
It will hook up just like hooking up a vcr or camcorder.
Just hooked up the card and am getting tv/Satellite on my PC...Wooohooooo Used the coax connectionon back of sat reciever and ran that to the All in wonder. Recorded a little stuff. Now the stupid question...What do I do to get it on a DVD to play on my set top. I have the newest Nero
Lab
You have to have a dvd authoring program and a burner.
You solved the easy part.
Now you need to do some more reading. Just look to the 'Guides' to the left.
Short version. You make your recorded video DVD compatible, then author it, then burn it. Nero may do all that for you, depending on the version. I don't really recommend that method. For good quality, IMO, you can use a program like TMPGEnc DVD Author for the authoring of a compatible video. Check 'What is DVD' also to the left for the specifications. I just know you are going to have a few more questions. Good luck!
I'm sure you are right. I did a capture and burn with Nero....YUK...Picture looked terrable. Think it captured at too high a rate?? Not even sure what I'm talking about. Should it capture at 480x480 If so..It did not 720X480 I think..If that makes any sense
Lab
Hello,
480x480 is SVCD.
720x480 is dvd.
If your source looks bad you can't make it look better (not much anyway).
Source looked great on the PC...Then when I did the nero thing...It went to poop. The card also had Pinnacle studio 8 I'll give that a try.
Big question. If I'm looking at live tv and it looks good. Should it not look good when on the DVD
Lab
you can look into this if the Computer and your TIVO are in separate rooms.
http://www.radioshack.com/product.as...5Fid=15%2D2572
Hello,Originally Posted by lablover
Not neccessarily.
If your bitrate is really high on the capture and you have to squeeze it to fit on a dvd then it will suffer in quality.
But usually what you see is what you get.
Keep practicing and you'll get the hang of it.
I'm sure I'll have more questions as the days go on. I just need to study it more
Thanks for all the help and watch for more questions
Lab
Oh yea..I also have Tivo...Another new game I'm sure. No sure how to make Tivo and the all in wonder work together
From what I have read, you can also get a DVB card for your PC ($100) and run the dish signal directly into your PC. Then your picture never goes analog... and you keep the HDTV resolution on those channels too.
Darryl
Direct transfer
By Jomapil in forum ComputerReplies: 3Last Post: 1st Nov 2009, 11:45 -
Direct x
By hamilton accie in forum ComputerReplies: 2Last Post: 6th Aug 2009, 05:04 -
4:3 to 16:9 direct conversion?
By ibantxo28 in forum Video ConversionReplies: 0Last Post: 19th Feb 2009, 03:00 -
Direct to External HD
By Galahad in forum Camcorders (DV/HDV/AVCHD)Replies: 9Last Post: 20th Jun 2008, 05:11 -
Direct TV DVR to DVD
By cspring72 in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2007, 17:00
