I am interested in buying a divX player.
i dont know anything about them...other than they play divx movies.
q1-i was wondering...if i were to burn 8 divX movies (500MB each) on to 1 dvd,Then would i be able to play that dvd in divx player?
is it as simple as that?^
q2-what divx player u recomend?
thanks![]()
Thread: question about divX players.
Q1 - yep, it's that simple.
DVD/DIVX players will give you an on-screen directory listing of the directories/files on the disk and usually show an icon against each filename indicating what type i.e. DIVX, MP4, MPG, VCD, DVD etc.
You just use your navigation buttons on the remote to make a selection from the directory. While playing, the 'Next' and 'Previous' buttons will switch between files and it will automatically play the next file in the list until it hits the end of the list.
Q2 - there are so many available now and which ones will vary from country to country - have a look at the player reviews on this site to get an idea. I'd recommend getting one that supports many different formats (even WMV if available).
q1 - yes.
q2 - I have the Zensonic Z330.
Go to http://www.videohelp.com/dvdplayers ,and make sure that you select DivX/XviD/MPEG-4, amongst any other features you require. This'll give you a whole range of players to choose from. Read the reviews, and you'll be half-way there
If in doubt, Google it.
There's an echo in here ! :P
Question about divX players
By guitardan in forum DVD & Blu-ray PlayersReplies: 4Last Post: 4th Jan 2007, 12:44 -
Divx Players that Support All Types of DIVX Codec
By mistermfive in forum DVD & Blu-ray PlayersReplies: 10Last Post: 25th Sep 2006, 23:29 -
OGM convert to DivX [for standalone DivX players]
By captormoonlu in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2005, 01:35 -
Newbie Question regarding Standalone DVD/Divx Players.
By Jman999 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 25th May 2004, 14:36 -
Hardware Divx players question
By afrodeziak in forum Video ConversionReplies: 8Last Post: 26th Apr 2002, 02:51
