VideoHelp.com Forum
    I'm using DVDRemake Pro V2.6.2
    I'm trying to backup my Top Gun DVD, removing all audio languages & subtitles except English.
    I've managed to remove the Language Menu and Copyright video scene (Thanks to JeanL's fantastic tutorials). Now I want to blank out the Audio button on the Main Menu and in the Subtitle Menu, blank out all buttons except for English.
    Let's look at the Audio button on the Main Menu. When I hide it using DVDRemakePro, the button still appears on the menu and I can not select any of the menu's buttons (I'm using PowerDVD V6).
    If I open the exported DVD in PGCEdit, I get the following error:
    can't read "::buttons::butinfo(1,17,1,numbuts)": no such element in array
        while executing
    "set msg "$msg ($::buttons::butinfo($cur_vts,$vobid,$cellid,numbuts) buttons)""
        (procedure "simulate_play" line 174)
        invoked from within
    "simulate_play"
        invoked from within
    "if {$idx == "-"} {
    				::main::set_listbox_selection end
    				set idx [lindex [::main::get_selection_indexes] 0]
    				bell
    			} elseif $::tr::now_playin..."
        (procedure "step" line 5)
        invoked from within
    "step	"
        (procedure "::tr::dvd_trace" line 321)
        invoked from within
    "::tr::dvd_trace"
        invoked from within
    ".mf.tb.toolbar.trace invoke"
        ("uplevel" body line 1)
        invoked from within
    "uplevel #0[list $w invoke]"
        (procedure "tk::ButtonUp" line 15)
        invoked from within
    "tk::ButtonUp .mf.tb.toolbar.trace"
        (command bound to event)
    Can any1 tell me if it's me or is there something wrong with the DVDRemakePro?
    +--Prince Of Thieves
    +--[ DVD Backup Experience =>
    +--"I've now ripped a few more coasters!"
    I haven't used PGCEdit, so I can't comment on what it is reporting. I have used DVD Remake Pro on occassion though, so here goes
    Keep in mind that buttons may also be part of the background image or clip. DVD Remake Pro cannot remove these images, only hide the subpicture above them, and hide the functionality.
    DVD Remake Pro also allows you to very easily screw up a disk by removing some integral part of the structure. Within the DVD Spec there is a lot of freedom and scope to create disks in some pretty ugly ways. It is easy to break them by getting to gung-ho. I have also had DVD Remake Pro create useless disks from what appear to be simple actions, such as removing a few buttons.
    Make sure you updated to the latest version (it gets updated pretty frequently), and try doing the exercise again scratch, just in case it was a random moment.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Thanks GunS1inger,
    Yeah, I think the buttons on the Main Menu are part of an array of some type, and the PGC commands maybe checking this, but until I use PGCEdit to do the job (the hard way tho), I won't know for sure.
    I will report back when I have an answer.
    PS. I gather that you are not saving the results of your DVDRemakePro DVD to a folder on the HDD but rather burning straight to DVDR? I would suggest exporting the results and then running, say, PowerDVD to check the results B4 burning.
  4. Member jeanl's Avatar
    thief,
    post here to get help on PgcEdit or to report problem. That's where r0lZ (the author) is most active. I haven't run into the problem you describe but I'm pretty sure r0lZ will have an answer for you...
    Jeanl
    MenuShrink a free tool to shrink menus into stills with or without audio!
    DVDSubEdit: a free tool to modify your subtitles directly inside the vob.
  5. Always Watching guns1inger's Avatar
    I always save to HDD and was testing first with PowerDVD. The problem is that PowerDVD will sometimes play things that are not compliant, or allow you to get past minor transgressions that a standalone wont forgive. I now use Mike's Tray Player, which is a little better at picking up oddities.
  1. Highlight buttons in DvdReMake Pro menu
    By c627627 in forum Authoring (DVD)
    Last Post: 25th Apr 2010, 18:21
  2. Proplem with mapping menu and title buttons using DVDit PRO 6
    By jakewoodblues in forum Authoring (DVD)
    Last Post: 14th Apr 2010, 16:56
  3. Replies: 0
    Last Post: 24th Dec 2008, 19:06
  4. DVDRemake Backup folder is not Playble
    By src2206 in forum DVD Ripping
    Last Post: 2nd Dec 2007, 13:03
  5. Removing/Hiding Buttons - Menuedit
    By _impromptu_ in forum Authoring (DVD)
    Last Post: 8th Nov 2007, 19:33
