VideoHelp.com Forum
Results 1 to 11 of 11
    Hi. Some help please. I would like to give my brother a fast dvd-rom so he can rip some of his own dvd movies and back them up. His kids are destroying the some of the cartoons dvd's he has. While searching, I was wondering is there a DVD-ROM that is really the fastest for ripping? What's the highest rip speed? 16X? Thanks
  2. DVD Ninja budz's Avatar
    get a LITEON DVDROM or a LITEON CDRW/DVDROM.
    http://www.newegg.com/app/ViewProduc...106-932&depa=1
  3. VH Veteran jimmalenko's Avatar
    16X is the highest speed possible, but practically it isn't obtainable in normal circumstances.
    There's a whole heap of threads that deal with the issue of fast DVD-ROMs.
    FWIW, I've got both a LiteOn 166S and a 167T and with firmware flashing, both have been known to peak at between 15X and 15.5X on occasion when ripping from DVDR.
    If in doubt, Google it.
  4. It would be worthwhile to look at the Aopen 1648/AAP . Check this out:
    Aopen
  5. Mod Neophyte Super Moderator redwudz's Avatar
    I know it's blasphemy, but most DVD ROMS rip at 16x or a little less. Usually doesn't make much difference which one you use. I like Toshiba, but Sony works well, also.
  6. Member glockjs's Avatar
    bah, show me the drive that holds those speeds through the whole process.
    i want the drive thats gonna shatter my dvd into pieces from movin so fast...whens that one comin out?
    PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
  7. Mod Neophyte Super Moderator redwudz's Avatar
    I said 'or a little less'; more likely a lot less. I just mean that most DVD ROMs rip at about the same speed.
    Just pisses me off that DVD burners can't rip at an equal speed. WTF, is it a conspiracy? Probably.
  8. VH Veteran jimmalenko's Avatar
    "It'll rip @ 16X, or a little less ....... like 4X."
    25% of it's capacity is more than a little less, isn't it ?
    Thanks to all. So if he gets the Plextor PX-716A DVD Burner which rips at 16X, it should be ok. Or do you guys recommend a DVD-ROM for ripping seperate. Thanks again to all.
  10. VH Veteran jimmalenko's Avatar
    Most burners are locked at 2X ripping speed, but this can be "removed" by flashing it with a hacked firmware. *I* personally believe you should get a separate DVD-ROM.
  11. Member glockjs's Avatar
    yeah buy the cheap rom to put the time on, and save the more spendy burner...well...for burning
  1. CD-ROM vs. DVD-ROM
    By Judson in forum Mac
    Last Post: 6th Apr 2012, 08:33
  2. Blue ray ripping on dvd rom
    By skorpinok in forum Blu-ray Ripping
    Last Post: 4th Dec 2010, 08:31
  3. Easiest and fastest ripping prog?
    By Valioser in forum DVD Ripping
    Last Post: 5th Mar 2009, 17:57
  4. Camera to DVD. Fastest way possible?
    By slaak in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 21st Jan 2009, 01:55
  5. Fastest from captured video to dvd?
    By larrym in forum Newbie / General discussions
    Last Post: 14th Jul 2008, 07:03
