I'm going to try to do it myself, but you guys are great at helping, so any tips ?
If your router has a print server built in, it's really easy. Just use the disc that came with the router. You may need to install a copy of your printer driver on each PC.
One other method is to use one PC as the print server. This is a little more complicated, but not too hard. The disadvantage with this setup is that the server computer needs to be on to use the printer from another PC.
If you are using XP as your profile says, really nothing to it with either method. I have a Mac G4 and 2 PCs that share a printer in another room using a router with a print server.
I'd recommend a dedicated print server. They can be found for around $50. The you won't have to worry about one of your PCs being up in order to print.
Nothing can stop me now, 'cause I don't care anymore.
I got it but I don't think I'll keep it this way, it's ok I can print from just one computer, thanks for the help.
Which Canon printer should I get to print on dvds?
By zanos in forum MediaReplies: 7Last Post: 4th Sep 2009, 18:58 -
INKJET printer - print heads
By orfajackson in forum Newbie / General discussionsReplies: 13Last Post: 15th Aug 2009, 06:51 -
How do I set up printer and monitor for wysiwyg
By anubis13 in forum MediaReplies: 0Last Post: 31st Jul 2009, 18:31 -
Lost printer CD, cant print to CD/DVD anymore
By Rudyard in forum ComputerReplies: 4Last Post: 19th Feb 2009, 18:50 -
Epson R 300 Printer - Print CD Software
By karlosfandango in forum ComputerReplies: 5Last Post: 29th Nov 2007, 12:12
Statistics
Newest guides
Latest tool updates
New media comments
