VideoHelp.com Forum
Results 1 to 9 of 9
    I tried to join 2 mpg files together with those tools recommand at this site, it all went wrong at the output file, anyone know the crue of this
    OK, I join one file with 30:00 total playing time and the other one with 17:00 total playing time, the output file's total playing time cames out 17:00 only, after the time reach 17:00 the player keep play the file but the time bar is full, there is no way to control the output file .....
    PLEAE HELP I am using window media player
  2. VH Veteran jimmalenko's Avatar
    ... and they would be .......... what ???
    If in doubt, Google it.
  3. You have not mentioned which tools you've used, but nonetheless there are quite a few mpeg2 editing tools outside this site might want to search a bit more. Not all work perfectly. However, I will share with you a method that has always worked with me. It's a bit long though. You will need two softwares which are free: PVAStrumento and MPEG2Schnitt. The first is used to demux the mpg file to its respective video and audio files/streams (you can used other software if you like. TMPGEnc does a decent job in demuxing as well) . MPEG2Schnitt is the editing tool but it only accepts separate audio and video files. After demuxing your two mpg2 files load the first into MPEG2Schnitt set the in and out points which in this case would be the begining and the end of the movie. then Press the NEW button. Load the second clip and do the same. Last step press on the cut button and the two videos will be joined. You will have to multiplex the audio and video files again to get your final mpeg file.
    Thanks, buddy, I think I confused you guys here, let me make it more clear.
    I need to join 2 or more mpeg1 files which had been rip-off from the VCD (I used "iosbuster" to rip the video from vcd), I tried using "mpeg joiner", "movie joiner", "video joiner" etc to put those files together, none of them work correctly at the output file, all the output file have problem in playing time as I mention earlier.......
  5. Member mats.hogberg's Avatar
    Why would you join them? If you want them on DVD, this can (should) be done during authoring (TMPGEnc DVD Author) - just add the 2 mpgs as 2 parts of the same title.
    /Mats
  6. Try MPEGVideoWizard from Womble. It will join mpegs without re-encoding and is easy to use. I believe there is a trial download that you can use. good Luck!
    Mark
  7. as Mats said, TDA will do a job.
    However, just because the files were on the same VCD doesn't automatically mean they have the exact same properties.
    They may have different video bitrates for instance. Some VCD authoring programs will allow this if they are seperate tracks on the vcd. It will be difficult to "join" them in that case without re-encoding.
  8. Originally Posted by mwkurt
    Mark
    I download the trial. I read that it works without re-encoding but when you go to export there is an option to choose CBR or VBR. Doesn't that mean it's re-encoding?
  9. VideoRedo is another option that works well without reencoding.
  1. MPEG Streamclip to join files but not transcode?
    By Corbey in forum Video Conversion
    Last Post: 28th Mar 2012, 11:58
  2. How can I join MPEG-2 files?
    By sofakng in forum Editing
    Last Post: 30th Jul 2010, 10:20
  3. Cut and Join VCD Files: tools that can Handle that
    By devilcoelhodog in forum Authoring (VCD/SVCD)
    Last Post: 15th Jan 2010, 21:57
  4. join mpeg files without re encoding
    By akakiami in forum Video Conversion
    Last Post: 12th Nov 2008, 01:18
  5. can't join simillar mpeg-1 files without re-encoding
    By sohaibrazzaq in forum Editing
    Last Post: 26th Jan 2008, 08:09
