Hi - I've got a file with two seperate audio streams in it - Is there anyway of choosing (forcing even) which audio stream should be played by default - currently the wrong one is being picked up.
Ideally, this should be transparent to the software used to provide the playback (as it doesn't have an audio stream selector)
J
Run it through mkvmerge/mmg and change the default track. Changing streams would depend on your player. i.e. if you are running mplayer then it would be -aid 1 or -alang eng, etc. but that won't be any help if you aren't using mplayer for playback.
Is it actually a MKS file or a MKV? Because MKS is supposed to be for subtitles. MKV for video and MKA for audio.
ok - will give it a go...Originally Posted by celtic_druid
oops - it is a MKV file - just has 2 subs, 3 audio tracks, 1 video, and 4 bitmaps!Originally Posted by celtic_druid
J
that did it - marked the audio track I wanted as default (and removed some tracks that I didn't need.
thanks.
No sound from matroska file with h264 audio.
By anarchyx34 in forum ffmpegX general discussionReplies: 3Last Post: 29th Oct 2009, 14:33 -
How to convert MKV Matroska to Avi or Divx including audio tracks and sub
By s.elmagnifico in forum User guidesReplies: 0Last Post: 16th Aug 2008, 08:47 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27 -
Clicks in DTS audio stream in MKV file
By MisterB42 in forum AudioReplies: 0Last Post: 23rd Aug 2007, 17:25 -
Problem playing .mkv (matroska)
By mk2006 in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2007, 04:33
Statistics
Newest guides
Latest tool updates
New media comments
