I have a film that changes color as it plays. Is there a virtualDub or other filter or technique to have more consistent color or saturation? Any of the adjustment techniques I have found change the entire film the same amount, which won't work in this case.
Thread: Consistent Color Filter?
Use TmpegEnc Xpress shown as below. If you dont know how to use it then use the below given guide link.
http://www.dvd-guides.com/content/view/55/59/
I thought this color correction only applied a single correction to the entire film. Can TMPGEnc correct different parts of the film by different amounts?Originally Posted by skullfullomagots
Cut your file into parts, encode each separately. The remerge when done. I do this in TMPGENC PLUS. Or I use my hardware proc amp, and capture separate files. Takes time and effort, but very possible.
What are the best blank DVDs? :: How to improve video quality? :: DVD recorder reviews? :: from DigitalFAQ.com
This is not possible as there are part of the film that shift gradually. I just need something to stabalize the color, at least a little.Originally Posted by lordsmurf
Then, no. Not unless you want to use a proc amp, and shift that gradually too.
Sounds like copy protection, however.What are the best blank DVDs? :: How to improve video quality? :: DVD recorder reviews? :: from DigitalFAQ.com
You can try the autogain and/or autowhite function of ColorYUV in AVIsynth.
Never used it, but it says it will scale your Luma values and act as an autogain filter.
Might be worth a shot.
http://www.avisynth.org/ColorYUV
If it works, or doesn't work, give feedback.
I only use colorYUV for it's analyze feature.
You need an app that supports keyframing effects settings. Vegas, Premiere Pro etc can do this.
Camcorder Color Denoise Filter for VirtualDub
By Soopafresh in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 17th Mar 2008, 14:30 -
60s & 70s Color Filter
By Tyler2000 in forum EditingReplies: 20Last Post: 6th Jun 2005, 20:25 -
Vegas 5: Color replace filter?
By Bajazz in forum EditingReplies: 0Last Post: 10th Mar 2005, 06:47 -
Vdub -> Filter -> Simple color
By Bull in forum Video ConversionReplies: 1Last Post: 28th Mar 2002, 19:34 -
v dub color correction filter...
By deltaboy in forum Video ConversionReplies: 2Last Post: 11th Feb 2002, 02:16
Newest guidesLatest tool updatesNew media commentsRecent DVD HacksSlysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial! About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
