VideoHelp.com Forum
  1. Hi,
    I have a Liteon 5005 and I tried to connect it to the firewire out from my computer and see if I could push out from Premiere Pro and record on the DVD, but the dvd recorder doesn't see any signal coming in.
    Is this normal or there is a way to make it work?
    Thank you
  2. Member mikesbytes's Avatar
    Can you push to your camcorder?
    Have a nice Day
  3. Yes, I regularly edit videos and then push them back to the camcorder with Premiere Pro and Pinnacle Studio 9.
    Do you know if the computer to DVD deck is something that is usually possible, or it is a fail?
    Thank you for your help.
  4. Member mikesbytes's Avatar
    Try pluging your camcorder into the DVD deck and see if the deck can record from it.
    Also try using some simple software on the pc, such as DIVO. Perhaps the software you are using wants to detect and recognise the device at the other end. If DIVO works, then try WinDV.
    Have a nice Day
  5. The DVD deck detects the camcorder, but doesn't record from it because the DVD deck is NTSC and the camcorder is PAL. But I can control the camcorder with the DVD remote control.
    What kind of programs are DIVO and WinDV?
  6. Member mikesbytes's Avatar
    DIVO and WinDV transfer video to and from the 1394 (firewire). Goto Tools and downlaod them.
    Have a nice Day
  7. Member bugster's Avatar
    This rarely works, tho I have heard a couple of people with specific set ups claiming success.
  1. Send DV through Firewire to a DVD recorder
    By nlec in forum Programming
    Last Post: 2nd Oct 2010, 02:56
  2. Firewire device to computer with no Firewire
    By dbuser2 in forum Computer
    Last Post: 24th Sep 2010, 20:32
  3. Expensive or cheap iLink/Firewire cable for video transfer?
    By chin569 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 2nd Jun 2008, 11:37
  4. best Firewire/ilink card for Sony Hdr-hc5e??
    By BrohiBoy in forum Capturing
    Last Post: 17th Jan 2008, 01:07
  5. need help on how to connect sony ilink to macbook on firewire 400
    By sasuke85 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 16th May 2007, 23:50
