VideoHelp.com Forum
Results 1 to 12 of 12
    Hi there
    I was on a trip to romania this spring and I wanted to send back a dvd that I created (NTSC) for them to watch. I've been looking around and I've been seeing lots of people that are saying that most UK players support NTSC, but would anyone know how prominent NTSC compatibility is over there?? I know this is a kind of way out there question, but maybe there are some Romanians on this forum or something??
    okay thanks for ANY help or input you might have!!
    Matt.
    My experience is most all of Europe is the same.
  3. Member hech54's Avatar
    About 25% of the "specialty" DVD's (music, documentary) are NTSC format. I just bought a concert DVD this week....NTSC....recorded and manufactured here in Germany.
    Most European DVD players are "well aware" of NTSC and will output a viewable signal from an NTSC DVD for their(our) TV's.
    There are still small pockets of Secam around....but forget where they are.
    There is little NTSC compatibility in Europe; however, NTSC DVDs do work on the large majority of DVD players and TV sets. That's due to a trick called PAL-60.
    An NTSC DVD is nothing but 480 scanlines per frame, 30 frames per second or 60 fields per second. PAL is 576 scanlines per frame, 25 frames per second or 50 fields per second.
    BUT there is a PAL flavor called PAL-60 or PAL-M (genuinely used in Brazil, if I recall correctly) which a PAL DVD player can output if it reads an NTSC disc. If the DVD player is capable to output PAL-60 AND the TV handles PAL-60 (not just the regular PAL/BG or PAL/DK), then the NTSC DVD is showing up fine.
    For the end user, this does not make any difference from handling NTSC natively (and I saw very few PAL TV sets that handle NTSC natively). It does make a difference, however, if you use NTSC VHS tapes. (A genuine NTSC signal, that is recorded on a VHS tape for instance, is more than just 480 lines/60 fps.)
    Cosmin
    The USA is inverse, NTSC-50 output with PAL discs on NTSC players. These basically just crop/stretch to fill the screen, and then change the color/signal needs. Framerate is left alone.
  6. Member hech54's Avatar
    Originally Posted by cosmin
    There is little NTSC compatibility in Europe..
    WHAT?
    THIS is the more accurate statement.
    Alright thanks a lot for your help guys. All I could remember about their tv and dvd player is that their tv is made by Hyundai with a SCART connection on the back, and the dvd player output was composite (Which I thought was odd... is that the norm??). Okay I might post again later with the actual DVD player maker later, would that be alright? I emailed them but they haven't got back to me yet. Thanks again!
    Matt.
    WHAT?
    If NTSC-DVD works well on a PAL TV via the PAL-60 trick, it doesn't necessarily mean that NTSC is itself well supported.
    When I say "NTSC" and nothing else, I mean the full-blown NTSC standard (carrier frequency, signal timing and shapes, luma coding, chroma coding, etc.). NTSC-DVD is just a tiny fraction of what NTSC really is: frame size, frame rate, and nothing else. It's the same with PAL, and again, PAL-DVD is stripped of all the analog details (which make the most of the "PAL standard", actually) and remains at the trivial subset composed by frame rate and size. This explains why, in spite of the fundamental differences between PAL and SECAM, PAL-DVD and SECAM-DVD are the same thing (and they're both simply called PAL-DVD). Also, in spite that PAL-60 is so different than NTSC, it has in common the frame rate/size (and no more than that!) yet NTSC-DVD plays on PAL-60 without any specially-implemented support.
    And, yes, NTSC does have poor support in Europe. There are few TV sets that recognize NTSC signals: people need to specifically look for a hybrid, three-system PAL+SECAM+NTSC model when they buy a TV set, if they really need NTSC compatibility. (There were a few exceptions, such as the old Goldstars; most of the Goldstars were three-system.)
    And if someone hooks an NTSC signal (e.g. the analog output of an NTSC camcorder, be it analog or DV), there are not so many chances that an European TV will recognize it. I know that about Romania, and I know that about the countries of many other European colleagues that I have here in Toronto, who failed to show their American home videos to their European families...
    But, hech54, I would be curious to find out if NTSC is really well supported in your country, and it's not just the NTSC-DVD simplification.
    By the way: if NTSC is not-so-well supported in Europe, PAL and SECAM have virtually no support in North America!
    Cosmin
    That's what should be, in theory. However, while there is a well-specified PAL-M/PAL-60 standard (and actually used in some countries), there is no NTSC-50 "standard". I cannot set up my DVD player to output an NTSC-50 signal, and I wonder how many DVD players can do that. Instead, it is the DVD player who does the job of converting 50fps-to-60fps and downsizing 576lines-to-480lines (my Panasonic RV-32 only does the former, actually; the picture is distorted as it's too tall, and the top and the bottom margins are getting out of the screen). My TV, or my TV capture card, get a genuine NTSC signal.
    Cosmin
  10. Video Restorer lordsmurf's Avatar
    The players do not convert framerates. It is left alone.
    The bottom line is there's no problem at all playing NTSC DVDs in Europe because virtually all their video equipment can handle NTSC.
    Enjoy!
  12. Member hech54's Avatar
    WHAT?
    Born and raised in America.
    Have lived in Germany for over two years now.
    I have friends and family all over the world....and since the majority of the world is PAL and not NTSC....I can safely tell you without playing with words.....that Europe is THE most NTSC Friendly place on earth.....and that includes VHS tapes as well.
  1. DVD players that play PAL & NTSC - do you need a PAL television?
    By ibzomie in forum Newbie / General discussions
    Last Post: 12th Dec 2010, 20:53
  2. players for UK, ntsc or multi-region
    By mbernard in forum Newbie / General discussions
    Last Post: 27th Jul 2010, 09:53
  3. Do They Exist? Blu-ray players that supports NTSC, PAL
    By xobituaryx in forum DVD & Blu-ray Players
    Last Post: 26th Feb 2010, 15:03
  4. Portable Dvd Players...PAL/NTSC Friendly?
    By Moontrash in forum DVD & Blu-ray Players
    Last Post: 25th Dec 2008, 18:41
  5. Format free DVD-R (plays in both PAL and NTSC DVD players)
    By Disco Makberto in forum Newbie / General discussions
    Last Post: 22nd Nov 2007, 00:34
