Hello does this player support XVIDs in res 960x528 or higher like 1280x544 also can it play ac3 5.1 on xvid files too?
Results 1 to 23 of 23
Thread: Philips DVP-642
Dn't know about those resolutions but i know it can play 5.1 AC3 in avi files, take note though, I don't actually use my player to decode the audio, it just passes it through to my receiver which decodes it but my guess is that it will work fine if you use the DVD player to decode AC3 audio.
OK thanks, now just waiting for the other question to be answered. Just trying to figure out as much as i can before i get this player.
anyone know anything about the rez the dvp-642 can handle?
I'm anxious to know the same thing as I have several episdoes of Lost in that resolution I'd like to try out. I've asked for this player for christmas, so after this Saturday I'll let you know how it goes!
Same here what you said is exactly what im doning too LOST is a sweet show... I will post my results as well
I am very skeptical that this player can play high resolution Xvid/DivX files. There is no evidence at all to suggest that it can. It should be able to handle AC3 in Xvid from what I have read. I have the player, but all my DivX files use MP3, so I have no way to test AC3 in it, but it should work.
Yeah same here but I'm hoping or maybe even if they come out with a new firmware to suport high res XVID's
Found the answer on an older thread, link is here: http://www.videohelp.com/forum/viewtopic.php?t=247248
Basically this is what someone said:
So I think the best you can do is reencode those HD files down to 720x480 anamorphic. It won't be HD but it'll be sharper than the lower res divx encodes.Your HD files are DivX HD? I've tried it and it dosen't work (I get half a picture and only half the scan lines) I don't believe there are any HD DVD players yet as there is no standard yet.
I just tried 1280x544 on a DVD-r and a Cd-r,Player says "RESO NOT SUPPORTED" didnt try 960x528. It did see the files on there,just wouldnt play it. I'll keep testing this.Originally Posted by djkerrona
Ok Thanks for the reply...keep us posted
I'm not sure about the resolution, but I encode at a maximum width of 640. It might support 720, but then again, you might get some minor problems, like synch between audio and video. I definitely wouldn't go beyond 720.
Also, I had an AC3 file and it goes out of synch with the video over time. After a few minutes it gets so bad (½ second) it's annoying. I think it only supports a certain amount of bitrate (audio+video) and high audio bitrate like AC3 files cause synching problems.
If I encode I use autoGK with ESS support and xvid 1.02. I set maximum width at 640 and CBR at 80kbs. This works for me.
I tested couple movies 800x ??? and it was working fine....
Audio? Ac3? On CD-r?DVD-r? Just want to try to get a good list together.Originally Posted by lifeisfun
XviD AC3 DVD-r
The max it supports is the HT (home theater 720x576 - 30fps) profile when encoding. It won't play back any of the HD trailers from the DivX site.
Any XviDs over 720 wide wouldn't play (get the same Res not supp).
Just to clarify that when I posted about the AC3 problems I had above, that was for an AC3 file that was 5 channels with a CBR of 448kb/s. The video was 640x336 with 1246 kb/s. So it required a little more than the DVD player could handle. It played fine, looked and sounded great, but after a couple of minutes you would notice the desynching of the video and audio which just got worse as time went on. I think it's best to keep the audio below 256kbs and preferably around 80-128kbs.
I don't think so ....Originally Posted by live4ever
I have couple files Xvid/AC3/800x ? and they all play fine
I read a manual for Div-x certified JVC player, and it said max. resolution support for DivX was 720 and max for mpeg4 (xvid) was 640. It also suggested using 128 kbs for audio. I would think these are similar for the Philips DVP642. Maybe you can play files at 800+ resolution, but remember that most TV screens only have a resolution of 480 lines (not sure if this is the smaller of 640X480) and therefore most people don't need anything bigger than 640.
I have 1280 x 720 High Definition projector :POriginally Posted by giannid
http://www.divx.com/hardware/detail.php?p=34
"New from I-O Data, this HD-capable AVeL LinkPlayer 2 with its network capability will let you play your digital videos directly from your computer in addition to standard DVDs and DivX files from a CD. Having recently achieved DivX HD Certification, this player supports DivX HD at 1280x720 and has USB 2.0 for USB storage reading. "
Cool player but i don't think its worth $249 USD.....you could buy an XBOX for that much and it will pretty much do everything that player can...im just hoping the DVP-642 will play HD XVID files either outa the box or with a firmware upgrade
Hello, just got this player...early christmas present
. I have tested some movies and episodes and the ones in 960x544 didn't work. but ones in 540x??? work perfectly...I was wondering if there is a guide i could follow to convet the 960x544 res to 720x480 so I can play them in my player.
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 12:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 02:22 -
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 16:26 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Jun 2007, 23:16 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 14:36
