VideoHelp.com Forum
Results 1 to 9 of 9
  1. I have six AVI files that are one gigabyte each that I need to join together. I searched the forums and it seems the program most recommended is VirtualDub. But when I used it, it took an hour to produce a file that was 42 GB. How can six individual files that are one gigabyte each turn into 42 GB when joined together? More importantly, what freeware/shareware program can I use to join these files? They all have the same properties, so I don't need anything complicated. Thanks in advance for your help.
  2. Member somebodeez's Avatar
    You have to make sure both the audio and the video are set to "Direct Stream Copy".
  3. VH Veteran jimmalenko's Avatar
    I'd say your virtualdub problem was that you saved it as uncompressed video and/or audio. The way to fix this is to go to Video > Direct Stream Copy. It probably wouldn't hurt to go to Audio > Direct Stream Copy either. Then File > Save as AVI.
    If in doubt, Google it.
  4. Originally Posted by jimmalenko
    Did that, thanks. It's processing the job now. It says the total time to save is 45 minutes. Does that sound about right?
  5. VH Veteran jimmalenko's Avatar
    I think it depends on the total number of frames, and without seeing what computer you have (please fill in your specs ), it sounds roughly in the ball park for what I would expect.
  6. Ok, it just got done processing the job, but it's still a lot bigger than 6 GB. I selected Direct Stream Copy for both audio and video and the resulting file still ended up being 28 GB. Doesn't that seem a little odd? I don't understand why it has to take so long either. Isn't there a program that will just stitch together the individual clips?
  7. VH Veteran jimmalenko's Avatar
    That's a bit strange .......
    One AVI Joiner I used to use with great success is Peck's Power Join - apparently this uses virtualdub "remotely". There's also a guide here for virtualdub itself, but it seems that's what you're doing ATM so ???
  8. I have a program called VOB Merge that I use to merge M2V and AC3 files, but it can also merge AVI, WMV, etc. Just add the files, put them in order, press the merge button and you're done.
    "Can You Dig It!"
    where did you get the 6 1GB files from
    seems an odd size for avis
    what program did this
    assuming each 1GB file is 90 minutes long i would estimate joining time to be in the region of 6-10 minutes
    perhaps the audio was uncompressed as i would expect uncompressed video to take a bit longer than that
    although to gain 20 gig of audio even if files were 10 hours in total
    20x1024x1024/10/60/60 to give an answer in kbytes/s
    x8 = 4000kb/s
    insane 31x the quality of mp3
    so is likely you are still saving as uncompressed avi
    i guess 45 minute write time for 26gb when reading from the same disc is about right
    put the files through avicodec to determine that they are indeed avis and what codecs are used
    also stick through the large file
    will let you know size of video size of audio how many audio streams too
  1. Replies: 9
    Last Post: 3rd Jun 2010, 18:21
  2. Simple question....... what is the best way to join AVI files
    By True Colors in forum Newbie / General discussions
    Last Post: 24th Apr 2010, 21:22
  3. Replies: 32
    Last Post: 1st Oct 2009, 07:29
  4. Replies: 6
    Last Post: 8th Sep 2007, 02:59
  5. Replies: 1
    Last Post: 26th Jun 2007, 08:16
