I am trying to use the front firewire connection with my Sony TRV-18 camera. I keep getting a cable not connected message even though it is definitely connected. I am using a standard 4 wire to 4 wire cable. I have set the input on the RDR-GX7 to DV. My camcorder is on and in VCR mode. I have checked all settings and cannot get this to work. The firewire output from the TRV-18 works fine with my computer and I am able to upload and download DV video. I am sure it is probably something simple that I am overlooking. I would appreciate any suggestions anyone might have.
Results 1 to 9 of 9
Thread: RDR-GX Recorder and Firewire
hmm..firewire on my rdr-gx7 works fine...have you successfully used that cable elsewhere (e.g. is the cable somehow defective?)...also, try various combinations of devices on / off when you connect...suggest recorder on and camcorder off, then turn the camcorder on into VCR mode..also, sony email support has been pretty good for me...
"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
rbrown3rd;
If I not mistaken the Gx 300 does not have a firewire interface
but only S-video and composite. And that why I returned mine few months ago and waited for the Gx-900. :P
Let me correct my first message in this thread. I have an RDR-GX7 not an RDR-GX3.
Perhaps it is the order of turning them on. I will try that. The I-link cable is nothing more than a 4 pin to 4 pin cable right? Is there anything special about Sony's I-link cable that distinguishes it from any 4 pin to 4 pin firewire cable?Originally Posted by DaveS
nothing special about the cable that I'm aware of...I'd try another cable as well, just to eliminate that cable as the source of the problem..Originally Posted by rbrown3rd"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
I used the cable to connect to my laptop to upload video from my camcorder to the hard drive. It worked perfectly. So, it is not the cable. I tried connecting to the RDR recorder and I get nothing but a purple screen and when I try to record from the camcorder to the RDR recorder I still get the message "cable not connected." This is very perplexing.
call / email sony
Emailed them and got nothing but the standard setup routine. Plug in cable, set camcorder to vcr mode, record from tape to DVD. Not much help. Will call if I can find the number.
Sony dvd recorder rdr GX210 Problem
By anthony nunoo in forum DVD & Blu-ray RecordersReplies: 2Last Post: 31st Oct 2010, 00:41 -
Sony RDR VX420 Combi Recorder
By Megamaniac in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2009, 09:19 -
WOOT! Sony RDR-GX255 DVD Recorder for $55
By lordsmurf in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Sep 2009, 20:06 -
Imac and Sony dvd recorder rdr-gx315
By diablo_ogre in forum MacReplies: 0Last Post: 17th Apr 2008, 09:27 -
HELP! Not so great quality with new Sony DVD Recorder - RDR-VX555
By w@ntonsoup in forum DVD & Blu-ray RecordersReplies: 3Last Post: 4th Oct 2007, 17:48
