I've been trying without luck to buy Maxell 3X MXL8 dvd-ram media that was shipped with the unit (and works fine). Have not found the Maxell product, but did pick up panasonic 5-pack at Walmart (! - thanks to previous post). On the box it says "ver. 2.1/3X rev. 1.0 standard, and is capable of recording at 2x and 3x speed." On the bar code patch there are two numbers: top: LM-AT120LU5; bottom: 0 37988 01348 7.
Before I rip this open and make it unreturnable, can anyone tell me if this media is compatible with the 4040B?
Yes but 3X are for newer burners only. Never had any problems with the new 3X compatible discs in a 2X burner...
Lets see, your writer uses 3x media & you want to know if 3x media works with it? I'd say yes it does.
Can't find RAM compatible with Motherboard
By AuroEdge in forum ComputerReplies: 5Last Post: 15th Jan 2010, 21:40 -
Compatible RAM.
By A Traveller in forum LinuxReplies: 3Last Post: 10th Oct 2009, 10:44 -
region free codes please: HL DT ST DVD RAM GSA T20N
By rjl24 in forum DVD & Blu-ray WritersReplies: 3Last Post: 20th Jun 2009, 18:22 -
LG GSA-4160 stopped reading DVD-RAM disks.
By lennyt in forum Newbie / General discussionsReplies: 1Last Post: 8th Nov 2008, 13:56 -
GoldStar GSA-4160B stopped reading DVD-Ram disks
By lennyt in forum DVD & Blu-ray WritersReplies: 3Last Post: 2nd Jan 2008, 11:12
Statistics
Newest guides
Latest tool updates
New media comments
