Ok well I really dont wanna argue this topic...
I use Mytheatre to record my DVB streams off Bell Expressvu, and when I record (capture) the PPV (pay per view) events I get them in the following information: ---->
MPEG-2 file
704*480 resolution
29.976042 framerate
48000 khrtz Audio
3150 kb/sec Bitrate (varies from event)
Thats what my DVB MPEG file is...and all those specs are DVD Compatible. Some channels I agree are 480*480 but mostly are 704*480. And since the ppv events always end under the 4.37 gig margin, i just aiuthor it and it works.
I use TMPGEnc DVD Author for authoring my mpeg files. And yes I agree it does not load on authoring programs, but that only happends when I edit it. For example... If i were to cap something and after it was done I needed to delete the first 20 seconds of the video because its from a previous show, i prob trim the first few seconds to make it look really nice, but once modified, and re-saved, the mpeg file somehow becomes un-usable. So my solution to that was from my previous comment, use Project X to do it.
Usually I need to modifiy all my caps because I cannot ever get a perfect beggning to end segment. So you load the mpeg file in MPEG2CUT, slice it, resave it, then load it in project x to demux video and audio. And it should work... This process took me over 14 demuxing programs to figure this out, its the only one that works flawlessly with DVB mpegs. And yes its a secret lol.
Closed Thread
Results 1 to 10 of 10
Thread: DVB streams off Bell Expressvu
Most common DVB these days is 480x480 and 544x480. Some of this depends on your provider, your location, etc. Even then, DVB structure is not the same as MPEG-2 for DVD. Some are not even MP@ML. And many have GOP length too long.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Well im talkin bout DVB-S, and when ur dealing with OTA DVB doesnt really matter what location your at, BELL is picked up anywhere in north america.
... and the GOP is too long, you just ignore it when it tells you on TMPGEnc DVD Author, it works for me all the time
How are you legally able to download Bell streams?
Bell is a DVB stream, so im "legally" getting the DVB stream off my DVB card...
Isn't BELL the encrypted Canadian DVB satellite service?
And encryption equals an inability to download?Answers to Common Video Questions:
Yes encrypted, but only for the HDTV channels.
Huh? Bell has been then brother of DISH for as long as I've known about satellite tv, and it's always been using NAGRA encryption on ALL signals. It even says so on lyng-sat sites.
heheh, well than im using some sort of software to bypass the stream, whats the big deal anyways wether its "legal" or not. Heheheh
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator lordsmurf
I was hoping to hear about some new service, or some new hardware ... something to suggest the DVB community in North America has finally gotten with the program. I've not been watching it for several months now.
Figures.
Canadian Satellite: Bell or Starchoice - Your experiences
By HillJack in forum DVB / HDTVReplies: 26Last Post: 4th Dec 2011, 10:03 -
DVB-S/DVB-S2 Satellite Receiver with direct HD,SD/SDI output not HDMI
By rahemeen in forum DVB / HDTVReplies: 1Last Post: 19th May 2011, 05:38 -
Bell 6131 made into hd pvr
By PSS2 in forum Media Center PC / MediaCentersReplies: 0Last Post: 4th Apr 2010, 19:25 -
DVB-T streams analizer
By -Sandro- in forum DVB / HDTVReplies: 0Last Post: 17th Sep 2009, 16:15 -
Captured dvb-s dvb-t mpeg video to DVD
By tonut in forum Authoring (DVD)Replies: 6Last Post: 7th Sep 2007, 07:02
