Closed Thread
  1. I have tried several ripping tools DVD shrink + dvd decrypter and they both run my processor at 100% is this normal for everybody PC or is it piticulare to my computer setup.
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    What does it run at when not ripping?
    The reason I ask is because I had Time Sync installed and it went batshit and ran in an endless loop somehow that bumped up my CPU load by 40%. Once I ununstalled it it dropped back down.
    Ripping with DVDShrink my CPU load is about 30%.
    Many things can affect that. If you have a screaming fast HD and a fast bus you could see a higher percentage. Slower, and the CPU ends up waiting for the other components ....lower percentage
  3. with 4 aplications running 1 playing MP3's, 1playing a DVD , enternet explorer and Outlook my PC is running with 25%
    http://www.videohelp.com/forum/viewtopic.php?p=1153696&highlight=#1153696
    Replacing warning for another post.
    / Moderator Cobra
    Apr 2003
    Largo, FL
    DVDShrink might run at 100% when it's analysing or encoding. I've never had DVDDecrypter run much over 15-20% when ripping. Are you running them both at the same time?
  5. no I have nothing else running at all just one of thos applications at a tome. It is when it is encoding it runns at 100 %. On another subject I am trying to download a copy of DVD X Copy Platnum but teh ones I have downloaded the crack keygen doesn;t work any ideas whare I could download a copy that installs properly.
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator Cobra
    ***Warning expired***
  6. 1. Little tip. Don't mention warz its against forum rules.
    2. When encoding your CPU will generally run at 100%. Its a processor intensive task.
