is there any way i can play my video files encoded with HD cause I got a lot of them and I have movies the same quality and they are encoded to where I can watch them on the DVP-642 and that makes me a little madI really dont want to spend a lot of time coverting them cause my computer will probably crash so what should I do?
Thread: Philips DVP-642 HD
PEACE OUT TO ALL MY HOMIES
Your HD files are DivX HD? I've tried it and it dosen't work (I get half a picture and only half the scan lines) I don't believe there are any HD DVD players yet as there is no standard yet.
About the only way to record HD now is to get a Tivo HD or Replay HD hard disk recorder.
I do record HD content to standard DVD+r on a stand alone DVD recorder. Plays fine (not HD) on my HD set through a DVP-642 or the recorder.
UB
Small correction...
ReplayTV still does not make a high definition recorder.
Choices are Tivo/DirecTV, Moxi/your cable company, Dish Network model 921, or LG 3410 (which does over the air and unencrypted digital HD from cable).Bob Simandl ... somewhere near St. Louis
Your mortgage is not my problem.
Hey
Thanks, I guess that I'll just get my video coverted to DVD then. I'm getting a DVD burner for christmas and it might be a Plextor PX-712A, you can check it out at http://www.plextor.com/english/produ...rw_drives.html
I found a cheaper price at www.tigerdirect.com
I was searching for DVD players and found one that plays HD video. It is an AVeL you can see it at http://www.divx.com/hardware/
anyone think this is good?
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 12:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 02:22 -
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 16:26 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Jun 2007, 23:16 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 14:36
Statistics
Newest guides
Latest tool updates
New media comments
