Results 1 to 10 of 10
  1. Member s0tt0's Avatar
    I have problem watching divx/xvid movies with this player. I should have the newest firmware. If I play the movie then it plays it slowly but not smoothly (like in games you have fps 10, then you experience such thing). I have tried burning CD's slowly and fast but nothing helps always the same problem. There are some movies what it plays smoothly. Maybe someone can help me or have the same problem with this player.
  2. What does Gspot say about the AVI you are trying
    to play?
  3. Member s0tt0's Avatar
    to play?
    OK I ran 2 different files with GSpot. The first file my DVD player didn't play smoothly but the second file it plays perfectly.
    First file stats (this is not working):
    Filesize........: 698 MB (or 715,442 KB or 732,612,608 bytes)
    Filetype........: OpenDML AVI
    Video Codec 4CC.: xvid
    Video Codec.....: XviD
    Frame Size......: 640x352 (1.82:1) [=20:11]
    Video Bitrate...: 1407 kb/s
    Frames/sec......: 23.976
    Runtime.........: 01:00:51 (87,540 fr)
    Audio Codec.....: ac3 (0x2000) Dolby Laboratories, Inc
    Audio Bitrate...: 192 kb/s (96/ch, stereo) CBR
    Second file stats (this is working):
    Filesize........: 700 MB (or 717,642 KB or 734,865,408 bytes)
    Frame Size......: 608x256 (2.38:1) [=19:8]
    Video Bitrate...: 1087 kb/s
    Runtime.........: 01:03:38 (91,534 fr)
    Audio Bitrate...: 448 kb/s (5 ch) CBR
  4. Hmm.. looks ok but there are things Gspot does
    not tell us.
    Download MPEG4Modifier from http://www.moitah.net/ (you will need the Microsoft .NET Framework installed, which you can download from Windows Update).
    Use MPEG4Modifier to unpack the Packed bitstream.
    (Click on the unpack box, and delete the user data)
    It may take a minute or two for a 700mg file.
    Burn the new copy and see if this has fixed it.
  5. forget that.. OpenDML is not supported.
    I have no solution. Sorry.
  6. Member s0tt0's Avatar
    So no one has any solution to this? I only need to know why it plays the second file and not the first?
  7. I think you have run out of quick fixes; how much time
    is this worth to you?
    -You could reburn & check for media issues
    - ,, ,, use VirtualDub to check for frame errors
    ,, ,, ,, ,, to strip audio and remux
    ,, ,, ,, ,, re-encode the entire thing
    - check for player firmware updates
    - Try running it through Avi Fix
    all these can take a lot of time for a simple movie.
  8. Member s0tt0's Avatar
    It's definately not a movie's fault becuse there are many movies it doesnt play smoothly but there are lots of movies it plays smoothly too :P it's definately player's fault. But I have the newest firmware installed on the player.
  9. OK. good luck with it.
    It is simple, I had it too. With MPEG4Modifier you have to unpack bitstream. Also delete userdata. It worked for me.
  1. Pioneer DV-490K vs Yamaha S550
    By SAPSEC in forum DVD & Blu-ray Players
    Last Post: 19th Sep 2006, 11:48
  2. Yamaha DVD-S550 - nightmare with firmware v34/38
    By noekken in forum DVD & Blu-ray Players
    Last Post: 23rd Jul 2005, 13:03
  3. Yamaha DVD-S550 - new Firmware update with DivX sub support?
    By MheAd in forum DVD & Blu-ray Players
    Last Post: 11th Oct 2004, 11:43
  4. YAMAHA DVD-S550 - few questions
    Last Post: 21st Sep 2004, 05:29
  5. Yamaha S520 DVD Player
    By btvs2000 in forum DVD Ripping
    Last Post: 24th Sep 2003, 09:34
About   Advertise   Forum   RSS Feeds   Statistics   Tools
