VideoHelp.com Forum
  1. HI Hope you can me out this one has been driving me nuts
    Here is the situation
    I have a highdef tv broadcast that i have converted to standard dvd mpeg2. No problem there. I have demuxed the audio and video leaving me with an mpv and ac3 file. I have thouroughly checked the audio and video files out and they seem fine.
    After trying many programs out. DVDLab seems to be the only one that supports 5.1 channel AC-3 sound correctly. However when i compile the dvd. it doesn't take the sound at all and gives me a dvd with mpeg2 audio. which has no sound.
    Any help you could give me in this regard would be most appreciated
    Shaun
  2. What are the specs of the 5.1 stream?
    What bit rate? Any bad sync frames? What tool did you use to confirm the AC3 ES is valid?
    There is a reason why God gave us one mouth and two ears!!!
  1. Replies: 22
    Last Post: 6th Jul 2011, 11:10
  2. Replies: 10
    Last Post: 3rd Apr 2011, 00:05
  3. DVD with mono audio channel...can i convert to two channel
    By maass in forum Newbie / General discussions
    Last Post: 1st May 2009, 21:46
  4. One channel of audio in Premiere Pro 1.5
    By kippard in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 29th Oct 2007, 22:00
  5. How to create an Audio-Only DVD in DVDLab Pro (PART 1)
    By GordRocks in forum User guides
    Last Post: 7th Oct 2007, 00:53
