I'm a little confused. Checking some of my commercial DVD's (The Music Man is one), it states it is a 'Dual-Layer Format'. It plays fine however in my stand alone player.
Does this mean that to back-it-up, I would need dual layer disks and a dual layer burner?
I thought I was getting to grips with this DVD thing, but apparently not...
Thread: Dual Layer Format
Hello,
Those are dvd9 discs. If you have a single layer dvd burner you need to use dvdshrink or another transcoder to get it down to the size of a dvdr.
If you have a dual layer burner you can do a 1:1 backup with dvd decrypter.
BUT YOU DON'T HAVE TO HAVE A DUAL LAYER BURNER.
A single layer burner will work if you shrink it or split it to two discs.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Thanks yoda313 - I'll give it a try on my single layer burner just to get a bit of 'hands on' experience.
Didn't realise things were this complicated!
Hello,
No problem.
That's why sites like these are so important.
And in my opinion this is THE BEST site for video
I totally agree with that. Always have had an answer to my queries.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 01:02 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39
