There seems to be a bug in the way that ffmpegX calculates the duration of a .VOB file.
I have had the same problem with both versions 0.0.9p and q.
I tried to convert a VOB file and the progress went to 100% and then kept going to well beyond that number (a few thousand % I believe).
So I tried to narrow down the problem (and because I was trying to extract just part of a movie).
I started doing some testing at the command line by using the same hour long VOB file and ffmpeg, from inside of ffmpegX package.
If I do this at the command line:
>ffmpeg -i VTS_01_1.VOB test.mov
ffmpeg version 0.4.9-pre1, build 4731, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-mp3lame --enable-gpl --disable-vhook --enable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-pthreads
built on Nov 21 2004 19:41:49, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
Input #0, mpeg, from 'VTS_01_1.VOB':
Duration: 00:00:29.5, start: 0.236100, bitrate: 288957 kb/s
Stream #0.0: Video: mpeg2video, 720x480, 29.97 fps
Stream #0.1: Audio: ac3, 48000 Hz, stereo, 256 kb/s
Output #0, mov, to 'test.mov':
Stream #0.0: Video: mpeg4, 720x480, 29.97 fps, q=2-31, 200 kb/s
Stream #0.1: Audio: aac, 48000 Hz, stereo, 64 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop encoding
Note that it says that the duration aove is 29.5 seconds, when the actual video is perhaps an hour. It, and ffmpegX, will correctly convert the whole file however.
The real problem that I have run into is that I wanted to skip part of the video. Since I could not see a way to do this using ffmpegX I went to the command line.
If I use a value of -ss of greater than 29 seconds I get a bus error:
>ffmpeg -ss 40 -i VTS_01_1.VOB test.mov
[mpeg @ 0x376034]read_seek: 0 3621249
[mpeg @ 0x376034]using cached pos_min=0x3fa2180e dts_min=2681968
[mpeg @ 0x376034]pos_min=0x3fa2180e pos_max=0x3fa5800e dts_min=2681968 dts_max=2718004
[mpeg @ 0x376034]0 1067587598 0 / 1067810830 0 1067810830 target:0 limit:2681968 start:0 noc:2718004
[mpeg @ 0x376034]pos=0x3fa5800e 2718004<=3621249<=-9223372036854775808
File 'test.mov' already exists. Overwrite ? [y/N] y
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Bus error
So it appears that both of the above things are due to problems in how ffmpeg deals with the duration of .VOB files.
If anyone has a fix, or knows of how to work around this, please let me know.
Thanks,
--Adam
Thread: Bug in ffmpeg duration
Way beyond 100% was something I noticed, too. I converted a ripped vob as a test and the progress was quick, but it would be nice to know exactly where you really are
Episode 6 Bug? Or Quicktime Player 7 bug?
By NY2LA in forum Video ConversionReplies: 2Last Post: 12th Apr 2012, 23:23 -
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum CapturingReplies: 1Last Post: 14th Feb 2012, 04:11 -
encoded video duration different than vob duration
By fatcharlie in forum Video ConversionReplies: 9Last Post: 4th Dec 2011, 10:04 -
FFMPEG adding audio to mpg video => QT bug
By Tom2me in forum MacReplies: 3Last Post: 6th Aug 2011, 05:27 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 02:55
Statistics
Newest guides
Latest tool updates
New media comments
