VideoHelp.com Forum
  1. Im really getting close to losing it with writing VCD's , a long long time ago i messed around with the PC (far too much in one sitting) and altered the ASPI (yes ?), jumper settings, drive layout, removed dvd drive, formatted - etc etc.
    Since then i have not been able to write CD's , FINALLY a few days back i got it working with music CD's which was great and all - but i need the drive alot for VCD's !.
    When i write a VCD on nero (after converting it myself in all the correct form) it begins writing it, stops at 4% where the 'USED READ BUFFER' reaches 100% - and HOLDS there, nothing happens at all for no matter how long.
    I downloaded this new program VCDEasy (Which is why im here) and it actually wrote the dam thing, i was happy as hell !. Then when its finished writing it gives out the error you see on the picture above.
    I really could do with knowing what the hell the problem is and how to fix it, also i have no clue what CD make mine is as its a bogg standard packard bell package from about 2 years ago - with little to no support from Packard Bell.
    PLEASE can someone help me and i will be highly thankfull ! - Thank You - Wo33eR
  2. Hi!
    According to the errror message, there's no CD in the CD-Writer or the CD inserted in the CD-Writer is not recognized.
    You're using SPTI with generic-mmc driver for the CD-Writer. That's good but some CD writers won't work with the generic-mmc driver, instead go into "Settings-CD Writer/Read-CD Writer and change the Write driver to generic-mmc-raw. That should work with no problems at all.
    // Znooky
  3. THANK GOD ! A reply !.
    Okay let me go test it, get back to u soon, cheers for the help and actually responding
  4. Drivers i have to choose are :
    Default
    CD2600
    Generic
    Generic-Raw
    Ricoh-mp6200
    sony-cdu920
    sony-cdu948
    taiyo-yuden
    teac-cdr55
    yamaha-cdr10x
    I dont know if there drivers on my PC or come with VCD easy or whatever.. i just dont know what to do now . The CD reads every time and nero manages to write music CD's no problem - just nothing will write VCD's !
  5. Ok, you got the error message of drive not ready dissappear. The new error message indicates that there's a problem with the driver for your CD-Writer.
    First I suggest you do a test on a CD-RW disc and lower the write speed to 4x. If this doesn't help, then there's another solution to your problem.
    Create only the bin file but do not burn it using VCDEasy. Instead use the "Burn Image" in Nero and hopefully that will work. You say that Nero burns music CD without any problem. This indicates that the Nero ASPI-drivers are working correctly with your CD-Writer. Therefore you should be able to write the bin file created with VCDEasy using Nero.
    // Znooky
  1. ?? Radio Stream No Longer Works ??
    By JaxGuy in forum Video Streaming
    Last Post: 23rd Nov 2011, 18:34
  2. WD External hard drive no longer works with my LG DVD Player
    By KarlKarlson in forum DVD & Blu-ray Players
    Last Post: 28th Feb 2010, 12:16
  3. AC3 no longer works w/ WMP 11
    By dmjerbear in forum Audio
    Last Post: 5th May 2009, 22:14
  4. DVD burning nightmares...it no longer works???
    By apollo1980 in forum Authoring (DVD)
    Last Post: 27th Dec 2008, 16:22
  5. All in Wonder TV Tuner no longer works
    By BeerSnob in forum Newbie / General discussions
    Last Post: 23rd Mar 2008, 02:52
