VideoHelp.com Forum
Results 1 to 14 of 14
  1. Hi,
    I am new to authoring DVD. So far I have created two DVD's using dvdSanta program. They worked just fine and had no problem watching DVD on TV. dvdSanta does have a facility to create menus, chapters etc. It is a very basic program. Since I have created simple DVD's using dvdSanta, I would like try creating DVD's that have chapters, menus. etc. But I don't know which programs to use. Can anyone recommend any other programs? Basically I am looking for easy to use program as dvdSanta that will allow me to create chapters, etc.
    thanks,
    greenmetal
  2. Member yoda313's Avatar
    Hello,
    Check out the tools section on the left
    Tmpgenc dvd author, dvdlab, ulead dvd movie factory are just a few that have menu creation capabilities.
    Kevin
  3. TMPGenc DVD Author is a very simple dvd authoring program, but i find it limited. I use DVD Lab, it's a little harder to learn but much more flexable...
    The distance between genius and insanity is measured only by success...
    Author:
    http://www.videohelp.com/tools?s=2#2
    My suggestion:
    Easy: TMPGENC DVD AUTHOR (TDA)
    Advanced: ULEAD DVD WORKSHOP 2
    You say you are new to dvd authoring, so I would recommend Tmpgec Dvd Author. Easy to use, free trial period, does what I want. As your experience progresses you can go to a more advanced program, but like me you might find TDA is all you need.
  6. Member Noahtuck's Avatar
    Just out of curiosity... in what way do you find it limited ?
    Originally a member since 2001, LONG LIVE TARAN's!!!
  7. VH Veteran jimmalenko's Avatar
    I too think it is kinda limited, but luckily almost everything I want to do is within those limits
    As an example, it is not real easy to set a firstplay title that plays as soon as you put the DVD in, and takes you to the menu afterwards, and is then not accessible from anywhere. For example, a disclaimer/copyright notice, or advertisement for your business. You can do it, but it is a heck of a lot easier to do in DVD-lab, or even by hacking VIDEO_TS.IFO than it is to do in TDA.
    If in doubt, Google it.
    Horrible font controls (just awful aliasing), and it's known to not properly link menu buttons. Everything is a title, and the MENU button won't work on players. No firstplay. Burning engine can make coasters (not the disc or file fault, bad burning engine).
    Just to name a few problems.
  9. Originally Posted by lordsmurf
    Author:
    My suggestion:
    Does ULEAD DVD WORKSHOP have support for preserving Prologic audio to create 3.1 AC3?
  10. Video Restorer lordsmurf's Avatar
    www.ulead.com and see
  11. Originally Posted by Michelle
    I'm pretty sure can only create 2 channel AC3 with it BUT if your AC3 audio track is already DVD compliant you can set it to not convert.
  12. Originally Posted by lordsmurf
    All I could find is that it creates Dolby Digital audio.
  13. Originally Posted by thecoalman
    I remember when I looked at Workshop 1, when I added AC3 and MPEG tracks, there was no way to tell if the program considered them compliant or not. Is that still the case?
  14. Originally Posted by Michelle
    I came across this information when researching how to insert 5.1 using DVDWS 1, I,ve never actually tried it but this info was on the Ulead Forum so I'm assuming it's correct.
    Not sure how to confirm they are compliant with 2. I never have this issue since all my video is compliant before it gets to DVDWS, there may be a better way but in DVDWS 1 when you click the the start button to begin burning you can watch the progress bar. I think it's the second step where it verifies the video and converts(if neccesary). Should only take a few seconds if it's compliant.
  1. What Program was used to create these menus?
    By BIGD22 in forum Authoring (DVD)
    Last Post: 21st Nov 2011, 18:43
  2. what program should i use to make some menus with diff chapters?
    By shadowofanubis6 in forum Authoring (DVD)
    Last Post: 28th Feb 2010, 23:48
  3. Best program to create a DVD (with menus) from MP4s?
    By namrufmot in forum Newbie / General discussions
    Last Post: 7th Jan 2010, 21:18
  4. Replies: 1
    Last Post: 18th May 2008, 11:36
  5. Best program to create a DVD with menus for home movies???
    By orbital517 in forum Authoring (DVD)
    Last Post: 12th May 2007, 21:14
