Hi,
I have an Sanyo Xacti C1 Camcorder which records in MP4 format with AAC codec. I tried to use a Philips 642 to play burnt DVD-R and it only plays the Video with no sound. I found out the 642 will play DivX with ic Mpeg4 with AC3, but it does not decode AAC. Can anyone recommend a DVD player, preferably cheap, that plays standard MP4 files with AAC audio?
Thanks,
JmsSeven
Seems unlikely that you'll find any - at least I've never heard of/seen any...
/Mats -
Hello,
Why don't you burn the aac as an audio cd then rip that to mp3??? Then you could encode that with the video and you should be ok.
On www.rarewares.org you can find different tools for MP4/AAC including softplayers and conversion utilities. I hope this might beof help.
CU
Schmendrick -
I read somewhere that the Philips 642 uses ESS chips that actually supports AAC. Do you know if the latest firmware upgrade for this machine supports AAC or when it will?
Editing MP4 files with H.264 (AVC) video and AAC audio
By Ahari in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2012, 16:30 -
MP4 w/ AAC ---> MP4 w/Compatible Audio
By NotSoEasy in forum Newbie / General discussionsReplies: 3Last Post: 26th Aug 2011, 15:41 -
Hi can anyone tell how to play a mp4(h.264 + AAC) file using dshow filter?
By kalpanaanb in forum Newbie / General discussionsReplies: 1Last Post: 31st Mar 2009, 08:58 -
How to create .mp4 file by using raw .h264 and .aac files for JW Player
By hakkinen in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 20:49 -
can i play mp4 format files on my dvd player
By vampelle in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2007, 05:36
