Hello DVD 'ers.
I am researching a new topic on subtitles. I'd like to insert subtitles
in my VOBS (much like DVD's) were I can inlude a them any play in my source ..
(ie, top or bottom; different color; etc)
Right now, the way I'm testing out my encodes authored to DVD disk.. in order
for me to see where I am in the video (time; chapter; title) that's playing on
my tv set ..
* either I look for my player (somewhere's) and view the tiny window, or
* I can have a subtitle with all the above, display at the bottom I guess.
Without having to actually "write" all this info inside the frames using an AVS
script or other ...
.. Currently, my dvd player lays out.. T01/01 C001/013 T00:00:30 for instance.
.. But it's watermarked inside the video, which could be anoying to some.
.. I would like to incorporate that same text (or similar) but at the bottom on my video,
.. in the black/boarder area.
How would I do this in a txt file or something, and add it in the VOB encoding,
much like ifoEdit does with it's celltimes.txt file (this holds
the chapter point, in the form of frame numbers) ?
Can anyone give me some suggestions on a approach to this ??
For my widescreen (4:3) aspect ratio encodes (cam footage) I would like to add
this info in the black/boarder areas at the bottom. I was wondering if ifoEdit
can do this. I search around it, but didn't find anything related to subtitles.
Thanks again for any suggestions,
-vhelp
make srt subs with for example subtitle workshop and use subtitlecreator to make sup files that you can import ifoedit.
Thanks Baldrick..
Actually, I D/L'ed this tool earlier this afternoon.
But, I got lost inside it very quickly. The help file is in HTML and I'm still lost.
Is there a guide or two on how to use this app by any chance ??
or, can someone walk me through an example ??
I would really appreciate it.
-vhelp
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 18:35 -
HowTo deal w/ nasty "audio streams have diff sample sizes" errors in WAVs!!
By KneeGrow in forum User guidesReplies: 0Last Post: 25th Jul 2011, 12:43 -
HowTo add permanent Letterboxed subtitles to video w/ Virtualdub, SRTtoSSA
By KneeGrow in forum SubtitleReplies: 19Last Post: 22nd May 2011, 05:28 -
Tip: How to add "detele" and "up" buttons in Vista/7
By roma_turok in forum ComputerReplies: 1Last Post: 3rd Jul 2010, 14:54 -
How to add subtitles link to "update ifos" doesn't work
By sinuhemoises in forum Newbie / General discussionsReplies: 1Last Post: 3rd Apr 2010, 14:35
Statistics
Newest guides
Latest tool updates
New media comments
