Woke up this morning and found my monitor has finally fired its last electron. That’s great news as I can finally buy a TFT model but I have a problem. I run, or at least ran, my current 21" monitor in a maximum resolution of 1024 x 768 due to the distance I have to sit from it. Any higher than that and I strain to read the text.
Now the 20" TFT replacement I want has a native resolution of 1600 x 1200 which would be way to high. I realise I could run the display at 1024 x 768 and let it interpolate the image but I'm loathed to do this as it inevitably blurs the image.
So my question is this: Is there a way to 'zoom' by a factor to make everything appear 1024 x 768 sized but run natively at 1600 x 1200?
Results 1 to 13 of 13
Sucks getting old doesn't itOriginally Posted by daveoggy
It won't blur the image -- but for 20" I would not go lower that 1280x1024 or 1280 x 720. But, at work, I have a 21" monitor that I run at 1600x1200 and it's not bad even with my 40+ yo eyes.Now the 20" TFT replacement I want has a native resolution of 1600 x 1200 which would be way to high. I realise I could run the display at 1024 x 768 and let it interpolate the image but I'm loathed to do this as it inevitably blurs the image.
Any software or hardware zooming would pixelate the image worse than using the system configuration at 1kx768. Try 1280x1024... you will be surprised on how well it looks.So my question is this: Is there a way to 'zoom' by a factor to make everything appear 1024 x 768 sized but run natively at 1600 x 1200?
Why can't you just pull the monitor closer? TFTs are very light.
Good luck. This is why I keep telling my mom she doesn't want a TFT. Its also why I don't use them now, they suck.
I have to lay on my bed and use the monitor at the end of it. i don't have enough space to fit a computer desk in and I don't want the monitor to my side for the sake of my neck.Originally Posted by Cobra
Maybe when I get older I'll be able to afford a bigger room :DOriginally Posted by Dr. DOS
Maybe I should just buy another CRT :(Originally Posted by Flaystus
What do you think of this as an alternative: Buy one of those large widescreen LCD TV's, as they have resolutions of about 1280 x 768, and plug my PC into that?
Make sure you can plug your PC into that. If it doesn't have a "D" type monitor connector, or the square digital one to match your PC video card's output, you'll have to get into buying an inline converter to modulate it as a TV signal, and in my experience, those usually end up providing a horrible picture.Originally Posted by daveoggy
If it's just a matter of having a hard time reading it at that distance why not enable larger fonts from within the OS?
FB-DIMM are the real cause of global warming
Get a 42" Plasma with DVI. :P
Nothing can stop me now, 'cause I don't care anymore.
Thats what I though initially but the problem is less obvious that that I think. For example increasing font size will do little for web pages, the start menu, non-standard programs... Or will it I'm not sure?Originally Posted by rallynavvie
About LCD TV's again, what are the response time like, are they on par with the LCD monitors?
It would be cheaper to get a bigger room in that case! :DOriginally Posted by ViRaL1
It should adjust font sizes for most every program that includes font information. So if there is text in a picture or something you'll have to blow up the picture to read the font as the OS doesn't see that as text.
There's also a maginifier..... start>accessories>magnifier
In case anyone is interested I've decided to buy the Dell 2000FP and a pair of binoculars
FireWire port has died
By ZiGGY909 in forum CapturingReplies: 2Last Post: 1st Feb 2010, 07:33 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 07:43 -
Philips DVP642 finally died...
By Krispy Kritter in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Feb 2009, 13:06 -
Version 2.1 died
By bfreas in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 18th Dec 2007, 02:42
