Hello, All;
I'm having a problem with the log and capture function in FC 2.0. Whether I try to capture my audio and video seperately or not, I'm still getting a "drift" of about 10 frames/hour so that the audio is happening earlier than the video. Does anyone have any ideas as to why this might be happening?
I'm running this using OS 9.2.2 on a Mac G4 Gigabit Ethernet dual 450Mhz. Many of my source videos are VHS, run through a Sony Digital 8 camcorder for the A/D conversion.
Any suggestions would certainly be appreciated! Thanks...
Thread: Final Cut Pro 2.0 sync question
Make sure your audio is synced up in your capture preferences. ie if it is 16 bit audio make sure it is set to 16 bit in FC.
Keeper of the "Unofficial" iMovie FAQ also for the lastest iMovie news click here
Your source for iMovie answers and what not! ;-)
when it happened to me (because of my Camera) I was always able to use iMovie for the capture, then bring the files over to FCP for editing. Always worked like a charm...
Wow, thanks for the info! Is there a chance that there's a camera setting I could/should be looking at to work around this in the future? Or is this just inherent to some kinds of hardware...?
Color Correcting in Final Cut Pro 7 (probably an easy question to answer)
By Huntr777 in forum MacReplies: 0Last Post: 18th Apr 2010, 11:49 -
Final Cut Pro - Question about a skip in video, how to sync?
By Huntr777 in forum MacReplies: 0Last Post: 18th Oct 2009, 20:56 -
final cut pro - advanced question
By marinebc11 in forum MacReplies: 2Last Post: 18th Aug 2008, 10:01 -
Final Cut Pro Aspect Ratio Question
By Jeff_NJ in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jul 2008, 10:25 -
Question About Widescreen in Final Cut Pro
By The Monkees in forum MacReplies: 1Last Post: 4th Apr 2008, 09:28
Statistics
Newest guides
Latest tool updates
New media comments
