  1. I'm having a problem with a program I am writing. It is a Video Renting program, and to calculate Late Fees I have something similar to:
    Late = (frmvhsout.txtFields(2) <= Date)
    That will return a true or false value. But, when frmvhsout.txtFields(2) is equal to a date older than today's Date or today's date, it gives me a false value.
    I can only assume that I am using the Date function in an improper way.
    Does anyone know how I could fix this? Or a better forum to post this in? Thanks.
  2. Member tekkieman's Avatar
    It could be moved to the Programming forum .
    Are you using VB or VB.NET?
  3. I didn't know there was a programming forum
    I'm using just VB
  4. Moving to the Programming forum
  5. Member tekkieman's Avatar
    Ok, first, you should probably cast the textbox entry to the same datatype using CDate(frmvhsout.txtFields(2).Text). From there, you should be able to compare using Late =(CDate(frmvhsout.txtFields(2).Text)<= Now). My VB is on my test server, and I only have .NET on this machine, but that should work for you.
    If not, let me know, and I'll fire up the other box.
  6. Thanks a lot! I've been trying at that for an hour or more.
    It now works perfectly...or atleast that one line of code
  7. Member tekkieman's Avatar
    No prob. Just give a yell if you get stuck.
  1. visual basic code
    By kudoshinichi in forum Programming
    Last Post: 21st Jan 2009, 08:30
  2. Visual Basic code
    By g_shocker182 in forum Programming
    Last Post: 9th Aug 2006, 23:40
  3. Attn: Visual Effects People - FXhome updates their software!
    By thefiddler in forum Latest Video News
    Last Post: 1st Dec 2005, 14:20
  4. Visual Basic (6)
    Last Post: 30th Jan 2004, 20:50
  5. Saving in Visual Basic
    Last Post: 27th Dec 2003, 16:20
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
