VideoHelp.com Forum
Results 1 to 24 of 24
  1. As a newbie I realise this may be an ugly way of doing this - but it worked for me! I have several UK DVDs that I bought last time I was there (I am an ex-pat Brit) and did not want to fork out $s to be able to watch them!
    1. DVD drive loaded with DVD region free (but may work without - see later).
    2. Copy DVD using DVD X-Copy Gold, but change Work Space Folder to somewhere you can easily access.
    3. Using IFOEdit use the patch method to convert PAL to NTSC (search this method on this site) and can also convert to region free here!
    4. Burn new DVD.
    Tips: I disconnect from the internet, turn off BlackIce and Norton anti virus autoprotect during the above procedure
  2. There is simple way too:
    You will need:
    - DVD Player that can handle both: PAL/NTSC
    - TV that can handle both: PAL/NTSC
    1.) Insert the disc to the DVD Player and watch the movie. Simple.
    I have Pioneer DVD player and Philips TV. Both support PAL/NTSC. This way you will save your nerves :P
  3. Yeah,
    Did not want to spend more money (don't have a DVD player and burner that can handle PAL) - but you are right!
    Best wishes from a cheap bastard (and proud of it!)
  4. Member hech54's Avatar
    That must be a bitch going from "we can play just about everything PAL Land" to NTSC OR NOTHING....I feel for ya' man....I've gone the other way 'round...
  5. Or just convert it during copy with DVDFAB.
    http://www.dvdidle.com/dvd-fab.htm
    "# Copy any DVD movie in perfect quality (no quality loss)!
    * Copy an entire DVD, including menus, trailers and special features.
    * Copy main movie only, excluding unwanted audio and subtitle.
    * Copy DVD movie content from original DVD disc or from hard drive.
    * Copy full multi-channel audio (AC3 5.1, DTS).
    * Copy episodic/season DVD movies, TV series, etc.
    * Copy NTSC/PAL DVD movies.
    # Split a DVD-9 into two DVD-5, and preserve menus on both discs.
    # Copy DVD-9 in 1:1 mode, and burn to double layer disc.
    # Remove all the restriction of DVD (CSS, Region, RCE, Macrovision, UOPs, etc.)
    # Burns DVD movies to any blank DVD Disc (DVD +/- R/RW).
    # Backup copy plays on any ordinary home DVD player.
    # Restore scratched or defective discs.
    # Very easy to use: our smart wizard will guide you step by step - very suitable for beginners!
    # FREE lifetime upgrade.
    # FREE lifetime support via e-mail, worldwide."
    DVDFAB forum
    http://www.dvdidle.com/forum/viewfor...83e3c9442be503
  6. Member hech54's Avatar
    I don't see how the above statement can be read as "convert"....and there is nothing in any of the tutorials that shows this somewhat much desired feature. You'd think the guide WITH this feature would be very prominent somewhere.
  7. Member Noahtuck's Avatar
    smiffo
    I'm assuming you are in the U.S. ?
    You can buy a cyberhome CH-DVD 300 dvd player for under $40.00 that will play pal dvd's & can be set to region free. I bought one last X-mas for my daughter and it works great!!! plays mp3 disc's, dvd-r, dvd+r.
    http://www.videohelp.com/dvdhacks.ph...ome+CH-DVD+300
  8. Member Noahtuck's Avatar
    I was under the impression that dvdfab WILL NOT convert PAL to NTSC ??
    And if your player don't support PAL to NTSC, as many of mine don't, won't help
  9. Member Noahtuck's Avatar
    Here is the link to best buy. $34.99
    http://www.bestbuy.com/site/olspage....&ref=10&loc=01
  10. Banned
    Why is it that whenever I see posts like this they use crazy software?
    Let me simplify your process.
    1. Rip with DVD Decrypter in file mode.
    2. Use IFO Edit.
    3. Burn.
  11. Member Noahtuck's Avatar
    2. Use IFO Edit.
    3. Burn.
    Using IFO Edit DOES NOT convert PAL to NTSC & only work's if your player will convert PAL to NTSC
  12. Banned
    2. Use IFO Edit.
    3. Burn.
    No s**t, Sherlock! I was just simplifying the method the original poster used.
  13. Member Noahtuck's Avatar
    2. Use IFO Edit.
    3. Burn.
    well, if someone did not know, & i have seen many people say that it would work when in fact it does not...
    Oh yeah, it's not sherlock... It's watson 8)
  14. Originally Posted by Noahtuck
    I confused it with DVDSANTA
    http://64.233.161.104/search?q=cache...ol%3DdvdSanta+dvdsanta+convert+pal+to+ntsc&hl=en
    " Very easy to use especially if you want to do a Pal-to-NTSC or NTSC-to-Pal DVD conversion. A couple quick settings and let it run. It does take a while to recode but worked great. "
    http://www.dvdsanta.com/faq.html#102
    "Does dvdSanta allow conversion of a PAL DVD to NTSC DVD?
    Yes it does! I have done that many times. Just load your PAL dvd into dvdSanta and click "Create DVD", make sure NTSC is checked."
    So, you could run the dvd through DVDFAB to strip macrovision and make it region free, then re-encode it with DVDSANTA.
  15. Member Noahtuck's Avatar
    Huh ?? now i have seen a few people, not newbies, post on here over time that DVD santa will NOT convert pal to ntsc ??
    Okay, now im gonna have to try it, but number one on the wish list is a proggie that will convert the whole movie with menus from pal to ntsc!!!!
    Or does it do that now also ??
  16. Member Noahtuck's Avatar
    That link does not take you to a help guide
  17. Member yoda313's Avatar
    EDIT
  18. OK - persuaded the wife to buy me a Cyberhome ch dvd 300 for Xmas. Idea is to use it to convert region 2 PAL stuff to region free NTSC - then burn back up using the computer. Problem is I need advice on which video card to buy (2.4 Ghz Pent 4 with 512 M ROM running XP and about 270 gig disc space)? Any info/advice out there? Off to the UK over New Year to see family and have 6 dvds to pick up and return with - so I need back up for use on other players!
    Many thanks to all who reply, I am learning a sh*tload.
    Seasons greetings to all!
    Smiffo
  19. Member edDV's Avatar
    The Cyberhome CHdvd 300 will play PAL discs but the TV needs to accept and decode PAL. Multi-system TV sets are few and far between.
    http://www.dvdoverseas.com/tv.htm
    What are the minimum TV set requirements to play a PAL DVD?
  20. If you go to the link Noahtuck (sp?) posted on 11/21/04 - tells you how to hack the cyberhome ch dvd 300 to convert PAL to NTSC! (as far as I can tell).
    Smiffo
  21. Member FulciLives's Avatar
    I was under the impression that the Cyberhome 300 model does not correctly convert 16x9 WS PAL DVD discs.
    If I am correct then you definately do NOT want it.
    The cheapest solution I know of that does work correctly is the Philips DVP-642 which can be bought in USA retail stores for about $69.99
    - John "FulciLives" Coleman
  22. Update
    Could not find Cyberhome ch dvd 300 so bought the 320 instead (Target about $39). Hack works fine but maybe a few tips!
    1. Response to remote seems a bit slow - be patient.
    2. When you do menu 1,9 a grey box with the numeral 1 appears - this is the region code - but there is no indication of this. Use the up/down arrows to change this to 0 and press enter. (Remember no disc in unit).
    3. Initially had trouble with this and ran a couple of "normal" dvds through the unit but then the hack worked fine.
    This unit was manufactured in Oct 2004.
    Thanks for all your help!
    Smiffo
    PS Only tried this with PAL region 2 (BBC made dvds).
  23. Banned
    If you checked the hacks section for the 320, you would have seen that I already detailed the different procedure.
    Also, I got mine for $27 at Target.
  24. Intended to buy the 300 - thus did not check out the 320 info. Sorry I did not see your hack - just trying to spread the good word.
    M*&her%$cker about the price though!
    Happy Holidays
    Smiffo
  1. Convert PAL Region 2 DVD to NTSC Region-Free DVD?
    By wizoomer95 in forum Video Conversion
    Last Post: 6th Aug 2011, 21:10
  2. Portable DVD player. Region free. Pal/NTSC
    By jtrinc in forum Portable Video
    Last Post: 16th Aug 2010, 09:28
  3. Does making a dvd player region free also allow PAL to display on NTSC?
    By dizmack in forum Newbie / General discussions
    Last Post: 25th May 2010, 19:50
  4. Ntsc BluRay players play PAL(region-free) dvdr?
    By spiritgumm in forum DVD & Blu-ray Players
    Last Post: 22nd Nov 2009, 18:48
  5. Region Free/ Ntsc PAL Compatible
    By veryconfused in forum DVD & Blu-ray Players
    Last Post: 19th Nov 2009, 18:53
