VideoHelp.com Forum
  1. Hello all,
    I own a SONY DVP NS-325 DVD Player, and I have noted an strange behavior on it.
    When I put on any a home burned DVD video on it, burned on a DVD+R or DVD+RW, or DVD-R (Can't test DVD-RW as my DVD burner doesn't support it) the player's LCD numbers start to run but they behave strange:
    Normaly this is a correct read:
    01:25,
    01:26,
    01:27,
    But instead of doing that, it reads:
    01:25,
    01:26,
    01:25,
    01:26,
    01:27,
    01:26,
    01:27,
    01:28,
    01:27,
    and it does that from the begining to the end of the video I'm playing back.
    Now the Video looks great and there are no pauses or fast skipping (once I had that behavior but it was the media [PRINCO] ) or video corruption at all. Just that strange number thing.
    The Media I'm using now is:
    MAXELL
    DVD-R = Manufacturer: Maxell, Code: MXL RG02
    DVD+R = Manufacturer: Ricoh, Code: RICOHJPN R01
    IMATION
    DVD+RW = Manufacturer: CMC, Code: CMC MAG W01
    DVD+R = Manufacturer: Ricoh. Code: RICOHJPN R02
    Note on the Imation labeled CMC DVD+RW disks:
    I use those disks for two things:
    VIDEO EDITION: Used only for testing how the final video will look like.
    DATA : Great media for large data backups.
    __________________________________________________ ___________
    For the final video, I use (mostly):
    MAXELL DVD-R,
    MAXELL DVD+R
    IMATION DVD+R
    I know that the DVD+R discs, which are manufactured by Ricoh (RICOHJPN R01 & R02) are just of "Acceptable Quality" for many, but until now, I had no problems with any of them.
    I don't think that could be the cause of the strange behavior with counter numers on my SONY DVD Player as it also happens with the MAXELL DVD-R discs.
    Now for video edition I'm using:
    Licenced:
    Nero 6 Ultra Edition
    Cinema Craft Encoder - Basic
    Shareware or Freeware:
    Virtual DUB Mod
    BeSweet and BeSliced
    The AC3 Machine
    ReJig and/or IFO Edit
    SRT 2 SUP
    SUP Remap
    Note: Final videos are set to be 4:3 Screen type, for NTSC.
    Ok, I think I gave you all the information you may need, if something else is needed, please let me know.
    ¿ What can be causing that strange number behavior ?
    As I said, the videos plays fine with no problems at all. That's the only strange thing I've noted.
    ¿Should I worry about it, can it be corrected?
    ¿Something wrong with the player?
    ¿Is this a common problem?
    Any help comming from you people, is appreciated a lot, because I don't know what to do with that "thing" as I don't even know how to classify it: Problem, Bug in the DVD Player, a Video Edition mistake, or what.
    Thanks in advance,
    Edwin Gonzalez
    "This World thru which we wander, is wonderful and strange. The only thing we can really know, is that everything will change".
  2. I have two NS325 and just tried two movies on PRODISC 8X also tried one on FUJI + RW disc and two movies on Imation + media all play as they should .I can make the player count up or down but I can't duplicate what your getting . Try making a movie with DVD Shrink and see if that solves your problem .
  3. It is a very strange problem indeed. But I don't why is that happening.
    It counts up, counts back and then up again. and that happens during all the time the video is playing.
    But as I said, the video plays just fine.
    Could this be a bug of the DVD player?
    Thanks for all.
    Edwin
    Edwin Gonzalez
  4. Originally Posted by billcay62
    Hi,
    Thanks for your answer. I will try DVD Shrink to see if this is a DVD software problem. I hope it is. If not, I will send thad DVD Player to SONY to see what's going on with it. I beleive that this is problem with the DVD player itself.
    Thanks for all. I will let you know know what happens after DVD Shrink.
    Sincerely,
    Edwin Gonzalez
    I have an NS700P that does the same thing on some burned discs, no idea why. It's never caused an issue that I know of.
  6. Strange problem, isn't?
    Not a real problem but still strange, it isn't supposed to do that.
    If any one have a clue on why this happens, please let us know.
    Thanks in Advance,
    Edwin Gonzalez
  1. Regions: Sony DVP-SR90 CD/DVD player
    By Marvinshadow in forum DVD & Blu-ray Players
    Last Post: 8th Oct 2010, 11:22
  2. sony dvd player dvp-ns67p without picture
    By kamran-ns67p in forum DVD & Blu-ray Players
    Last Post: 15th Aug 2010, 13:44
  3. My Sony DVD player SONY DVP- NS718 H
    By samyer in forum Newbie / General discussions
    Last Post: 2nd Feb 2010, 23:56
  4. Sony DVP S360 DVD player - No DISC problem
    By weenie02000 in forum DVD & Blu-ray Players
    Last Post: 5th Aug 2009, 08:43
  5. [Help] Unlock Sony DVP-NS78H DVD Player
    By RMO in forum Newbie / General discussions
    Last Post: 3rd Apr 2008, 15:59
