VideoHelp.com Forum
  1. Hello.
    I've searched the forums and cant find what I'm looking for (maybe I'm searching in the wrong places)
    The Case:
    Have converted from DivX back to DVD using Ulead DVD MovieFactory 3 Disc Creator. (several films - takes approx 8 hours per film)
    Now I found out that I forgot to make good menus. ULEAD makes VOB, IFO and the rest of the files.
    Is it possible to make a meny file without converting the DivX file again, using the existing vob files.
    Nilsek (in desperate need of a good tool)
  2. Member MackemX's Avatar
    yes it is possible to add menu's to the DVD
    you would have to load the DVD into DVDShrink and process it with No Compression. Get hold of Titlewriter (by FallenAngel) and then you can add a menu to it using one of the templates
    you could create you own menu to use and then replace the template menu with your own
    check out SmileyPic if you love using smileys :) (LINKSKI)
  1. Convert VOB files to Divx with DVD menu
    By xtof in forum Video Conversion
    Last Post: 1st Mar 2011, 15:29
  2. problems making dvd from vob files only
    By Dr_Sanguinary in forum Newbie / General discussions
    Last Post: 17th Nov 2009, 07:20
  3. DVD Demuxer tool making 0kb .VOB files
    By Madvillain in forum DVD Ripping
    Last Post: 6th Jul 2009, 04:11
  4. Making a DVD menu from .VOB files created by FAVC?
    By whatever911 in forum Authoring (DVD)
    Last Post: 16th Feb 2009, 03:13
  5. Add menu to existing DVD?
    By MilesAhead in forum SVCD2DVD & VOB2MPG
    Last Post: 2nd May 2008, 17:56
