VideoHelp.com Forum
  1. hi, i got crazy problems with my computer, can you help!
    ... i have been authoring using tempgenc, burning dvds with nero 6, i also have adobe encore installed just in case.
    and now for some reason (after a good couple of months) none of my burning software will not burn DVDs, ive wasted countless disks.
    but the strange thing is i can still burn cds.
    my thoughts are that im forced to buy a new dvd burner, thinking thats the problem,
    does anyone have any experience in these matters, and can advise me in anyway.
    thankyou.
    As DVD burning and CD burning use lasers with a different wavelength, it may be that your DVD laser has gone down. It may just need cleaning, otherwise, it's new burner time.
  3. Banned
    I agree with Richard.
    It may be new burner time.
    One thing to try before going out and buying a new one, is to flash it with the latest firmware. I had a problem with my reader not reading all discs. I was ready to just buy a new one, but decided to try flashing it first. Bingo, it has not failed me once since. Just a thought............
    Shovels Rule!
  5. You did not say what writer you have, nor what media you use or what computer you have.
    Try,.
    Uninstall in control panel & restart your computer.
  6. hi, thanks for the reply, to answer the following questions:
    i have a HL-DT-ST DVDRAM GSA 4081B DVD-+R/CDR burner
    and the disks i use are
    ritek printable grade A and ive also tried ridata, sony and packard bell
    Q? im a newbee so how do i flash the drive with firmware?
    as i post ill research it on google, but please reply back with suggestions.
    thanks again
  7. Originally Posted by future sheperd
    Look up the drive on the manufactuers site, you'll find the update. Check the instructions on the site before doing anything.
    Quick note, I had a similar problem with my DVD burner. It came with a new computer and the burning software it came with didn't support the drive. It needed the latest version. It was simply a matter of getting the correct software. This probably won't help you since you were already able to burn DVD's with it but I thought I might mention it.
  1. Samsung SH-S203N SATA DVD Burner stops responding during burns?
    By 1wheelken in forum DVD & Blu-ray Writers
    Last Post: 24th Aug 2009, 13:30
  2. Longevity of CDs and DVDs? Are my old CDs starting to lose it?
    By garybeck in forum DVD & Blu-ray Recorders
    Last Post: 19th Feb 2009, 19:16
  3. Burner stops while burning DVDs
    By standalone in forum Authoring (DVD)
    Last Post: 20th Sep 2007, 23:48
  4. burning dvds without dvd burner??
    By lordscrubba in forum Newbie / General discussions
    Last Post: 19th Jun 2007, 09:19
