I've branched out and obtained my first Matroska file hoping I'd be able to handle it when it arrived. Sadly I can't. It plays on the computer just fine in MPC, but I want to convert it to SVCD using TMPGEnc in the same way I do every other conventional DivX/XviD file.
I've browsed the guides and found only 4 so far on conversion of mkv files to something else. All four are not really what I want to do. They get far more complicated than I think I really need.
My mkv file contains video (obviously), 3 audio tracks, 3 different subtitles as well as chapters and covers (!!!). I don't need all that, but that's the way it came so whatever. All I want to do is get the english audio track and the video out of it in a format that TMPGEnc can accept as input. Does anyone here know how to do that relatively straight forward task?
Results 1 to 11 of 11
use mkvextractgui
Thanks for that but it doesn't work at all with my file. It can't find any streams at all in the file. It seems there's very little support for these Matroska files so far. Is there anything else I can try or would the best advice just be to delete it and don't bother with Matroska anymore?
try asking the mkv gurus in the doom9 forum section devoted to the new containers. It's weird that mkvextractgui can't handle the file.
Sorry, I had to go see about a girl
you can also try extract audio and video with virtualdubmod. audio under streams->stream list. and the video using video->direct stream copy and file->save avi.
Yeah that was the first thing I tried actually, but all I get is...Originally Posted by Baldrick
mkvextractgui is just a gui, you also have the maktroska toolnix installed as well, correct?
Blah, blah, blah
Blah, blah, blah
Actually I didn't realise that no, so thanks for pointing out the error of my ways. I shall try again.Originally Posted by nufan292
It looks to me as if mkvextractgui already contains those parts of mkvtoolnix it needs to work, so I don't think you need to download both to get it to work. In any case, I have downloaded both and put them all in the same folder and it made no difference whatsoever. There still aren't any streams in my mkv file it can recognize.
Oh ok. Didn't know that either. The version I got wasn't from this board, it was from another board in a thread made by the author. I wish I could help you, but never came upon this problem myself.
Blah, blah, blah
New to HC Encoder: .D2V files as input?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2011, 09:41 -
Demux Matroska files
By Anicsi in forum MacReplies: 4Last Post: 16th Dec 2009, 12:41 -
How Can I convert Matroska files without losing both 2 audio and 2 subs?
By shuyinliquid in forum Video ConversionReplies: 1Last Post: 9th Apr 2009, 13:58 -
matroska files playing problems
By pepevideo in forum Blu-ray RippingReplies: 4Last Post: 30th May 2008, 08:28 -
Another conundrum! How to burn Matroska HD files to DVD-R?
By expat in forum Newbie / General discussionsReplies: 3Last Post: 28th Sep 2007, 14:02
