These questions is mainly about resizing 16x9 movies.
Here's the questions
[1] Are all widescreen 16x9 only and never 4:3?
[2] Are all widescreen 16x9 always anamorphic?
[3] When using the resize filter in VirtualDub for a 16x9 movie, do I always use 480x360, then letterbox to 480x480? Or is that *only* for anamorphic movies? If so, how can I tell when to resize to 480x360 and not (some movie discs I rent don't say it on the actual disc).
Thank you for any replies.
Thread: All widescreen 16x9 anamorphic?
On #1, I know you can get 4:3 DVDs that have been letterboxed - it's quite common on the cheesier DVDs.
For #2 - I think that's mostly true, although I don't know for sure.
For #3, I believe the answer is yes, although the thing to do is download FitCD (from the Tools area) - it gives you all kinds of resizing options depending on how much you want to clip, how close you want to keep the aspect ratio, etc.....
I usually do
Clip(20,0,680,480) (clips 20 bits from left and right)
BicubicResize(480,382) (that's what FitCD says is correct)
AddBorders(0,49,0,49) (this is for CCE).
Then I mess around with the resizing and borders a little bit to force the black bars onto 16-pixel boundaries.
How do I get my 16x9 anamorphic clip to play letterboxed on a 4:3 screen?
By buddyreid in forum Newbie / General discussionsReplies: 6Last Post: 26th Sep 2009, 02:14 -
DVD Tv Episodes to PC and keeping Anamorphic 16x9
By saber001 in forum DVD RippingReplies: 7Last Post: 16th May 2009, 20:24 -
16x9 Anamorphic DV AVIs and Windows Movie Maker 6
By paulmedynski in forum Camcorders (DV/HDV/AVCHD)Replies: 18Last Post: 3rd Dec 2008, 16:38 -
Anamorphic/16x9 with FAVC
By bgart13 in forum Video ConversionReplies: 6Last Post: 15th Apr 2008, 01:52 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 22:15
Statistics
Newest guides
Latest tool updates
New media comments
