VideoHelp.com Forum
  1. hi.. i just burn a dvd data using nero, actually i was using dvd overburning features in nero with size "4600MB" (i know its not good for my DVD writer i was just testing), and at the end of burn process i got an error message... btw what is the maximum size of DVD data that nero can handle?? cuz my DVD-R said it can burn for 4.7G data, my data is not even reached 4.7G
    i save the log file:
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 06/05/2002 10:01:14 AM
    ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16/12/2003 7:18:06 PM
    Nero version: 6.3.1.15
    Recorder: <SONY DVD RW DRU-710A> Version: BY01 - HA 1 TA 0 - 6.3.1.15
    Adapter driver: <atapi> HA 1
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    CD-ROM: <SONY DVD RW DRU-710A >Version: BY01 - HA 1 TA 0 - 6.3.1.15
    === Scsi-Device-Map ===
    DiskPeripheral : ST380021A atapi Port 0 ID 0 DMA: On
    DiskPeripheral : WDC WD1200JB-32EVA0 atapi Port 0 ID 1 DMA: On
    CdRomPeripheral : SONY DVD RW DRU-710A atapi Port 1 ID 0 DMA: On
    CdRomPeripheral : HL-DT-ST CD-RW GCE-8523B atapi Port 1 ID 1 DMA: On
    CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 2 ID 0 DMA: Off
    CdRomPeripheral : OBVIOUS DVD-ROM MAGIC 626.00 obvious Port 3 ID 0 DMA: Off
    === CDRom-Device-Map ===
    SONY DVD RW DRU-710A H: CDRom0
    HL-DT-ST CD-RW GCE-8523B I: CDRom1
    AXV CD/DVD-ROM K: CDRom2
    OBVIOUS DVD-ROM MAGIC 62 J: CDRom3
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    ShowDrvBufStat : 0
    BUFE : 0
    Physical memory : 1022MB (1047276kB)
    Free physical memory: 548MB (562048kB)
    Memory in use : 46 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    9.11.2004
    ISO compilation
    7:44:39 PM #1 Text 0 File Isodoc.cpp, Line 6065
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet : TRUE
    Allow pathdepth more than 8 directories : TRUE
    Allow more than 255 characters in path : TRUE
    Write ISO9660 ;1 file extensions : TRUE
    7:44:39 PM #2 Text 0 File Writer.cpp, Line 124
    Writer SONY DVD RW DRU-710A running
    7:44:39 PM #3 Text 0 File Reader.cpp, Line 118
    Reader running
    7:44:39 PM #4 ISO9660GEN -11 File geniso.cpp, Line 3899
    First writeable address = 0 (0x00000000)
    7:44:39 PM #5 Text 0 File Burncd.cpp, Line 3167
    Turn on Disc-at-once, using DVD media
    7:44:40 PM #6 Text 0 File DlgWaitCD.cpp, Line 245
    Last possible write address on media: 2355199 (523:22.49, 4599MB), real: 4482MB
    Last address to be written: 2348959 (521:59.34, 4587MB)
    7:44:40 PM #7 Text 0 File DlgWaitCD.cpp, Line 257
    Write in overburning mode: YES (enabled: CD DVD)
    7:44:40 PM #8 Text 0 File DlgWaitCD.cpp, Line 2137
    Recorder: SONY DVD RW DRU-710A, Media type: DVD+R
    Disc Manufacturer ID: RICOHJPN, Media Type ID: R01, Product revision number: 2
    Disc Application Code: 0, Extended Information Indicators: 1
    7:44:40 PM #9 Text 0 File DlgWaitCD.cpp, Line 418
    >>> Protocol of DlgWaitCD activities: <<<
    7:44:40 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 813
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (150) not provided
    original disc pos #0 + 2348960 (2348960) = #2348960/521:59.35
    relocatable, disc pos for caching/writing not required/required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2348960 blocks [SONY DVD RW DRU-710A ]
    7:44:40 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 983
    Prepare recorder [SONY DVD RW DRU-710A ] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4810670080, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
    0 | lead-in | 0 | 0x00 | 0x41
    0 | 1 | 0 | 0x00 | 0x41
    0 | 1 | 1 | 0x00 | 0x41
    2348960 | lead-out | 1 | 0x00 | 0x41
    7:44:40 PM #12 Phase 24 File dlgbrnst.cpp, Line 1845
    Caching of files started
    7:44:40 PM #13 Text 0 File Burncd.cpp, Line 4177
    Cache writing successful.
    7:44:40 PM #14 Phase 25 File dlgbrnst.cpp, Line 1845
    Caching of files completed
    7:44:40 PM #15 Phase 36 File dlgbrnst.cpp, Line 1845
    Burn process started at 4x (5,540 KB/s)
    7:44:40 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2343
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    7:44:40 PM #17 Text 0 File Cdrdrv.cpp, Line 8120
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD+R (10), Part Version: 1
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 26053F h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    Disc Application Code: 0 / 0 h
    Extended Information indicators: 1 h
    Media type ID: R01
    Number of Physical format information bytes in use in ADIP up to byte 63: 56
    Media Specific [16..63]:
    00 00 01 52 49 43 4F 48 - 4A 50 4E 52 30 31 02 38 ...RICOHJPNR01.8
    23 54 37 09 00 3C 67 00 - AC 62 16 18 0B 0B 0A 0B #T7..<g..b......
    01 19 1B 0B 0B 0E 0F 01 - 00 00 00 00 00 00 00 00 ................
    7:44:40 PM #18 Text 0 File dlgbrnst.cpp, Line 1703
    Set remaining time: 14:40,355 (880355ms) -> OK
    7:44:40 PM #19 Text 0 File DVDPlusRW.cpp, Line 607
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    7:59:03 PM #20 SCSI -1037 File Cdrdrv.cpp, Line 1442
    SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03D90000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x63
    Sense Qual: 0x00
    CDB Data: 0x2A 0x00 0x00 0x23 0x05 0x40 0x00 0x00 0x20 0x00 0x00 0x00
    Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
    0x00 0x00 0x00 0x00 0x63 0x00
    7:59:03 PM #21 CDR -1037 File Writer.cpp, Line 304
    End of user area of this track
    7:59:03 PM #22 Text 0 File ThreadedTransfer.cpp, Line 229
    all writers idle, stopping conversion
    7:59:03 PM #23 Text 0 File ThreadedTransfer.cpp, Line 223
    conversion idle, stopping reader
    7:59:26 PM #24 Text 0 File dlgbrnst.cpp, Line 1703
    Set remaining time: 0:00,000 (0ms) -> OK
    7:59:26 PM #25 Text 0 File dlgbrnst.cpp, Line 1703
    7:59:26 PM #26 Phase 38 File dlgbrnst.cpp, Line 1845
    Burn process failed at 4x (5,540 KB/s)
    Existing drivers:
    File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 06/05/2002 10:01:08 AM
    File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28/10/2003 5:02:00 AM (Prassi/Veritas driver for win 2K)
    File 'Drivers\atapi.sys': Ver=?.?.?.?, size=86912 bytes, created 29/08/2002 12:27:50 AM (Adapter driver for rec)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  2. A DVD can hold 4.38GB, not 4.7. The 4.7 the manufacturers proudly splash all over is the size in billions of bytes, but computers use 1024 bytes = 1 kilobyte, so the 4.7Billion Bytes translates to 4.38Gigabytes. You need to shrink your files before they will fit on one DVD
    You're yet another victim of marketing hype :P
  3. huwhwuwhhww T_T its true im the victim, for others DONT GET TRICKED BY THOSE MANUFACTURES THINGY!!
  4. VH Veteran jimmalenko's Avatar
    Good work, cappy. Another newbie's hopes and dreams nipped in the bud
    If in doubt, Google it.
  5. Mod Neophyte Super Moderator redwudz's Avatar
    pido don't get discouraged, we all get burned by manufacturers one time or another. Overburning a DVD is a bad idea, as you found out.
    Nice avatar, though.
  6. thnx... redwudz T_T but now i found out, dont have to OVERBURNING my DVD-R cuz it's already big enough for my data, rite?!?! summary "dont be too greedy" human never satisfied for what he/she get, wants more,more,and moooorrreee..!! (...never end) :P
    btw i have a lot of avatars 1000+ w00t..!! nyehehehe
  1. (1) Burn failed !!
    By skinney6 in forum DVD Ripping
    Last Post: 4th Feb 2010, 18:01
  2. Does SVCD2DVD process and burn HD quality DVD from HD .ts file?
    By jeemak in forum Authoring (VCD/SVCD)
    Last Post: 21st Nov 2008, 22:03
  3. New DVD writer... Burn process failed at 2x (2,770 KB/s)
    By planetx in forum DVD & Blu-ray Writers
    Last Post: 8th Feb 2008, 15:40
  4. Nero failed burning DVD
    By DuBsTaR in forum Newbie / General discussions
    Last Post: 6th Jan 2008, 14:15
  5. Replies: 5
    Last Post: 29th Dec 2007, 20:49
