VideoHelp.com Forum
Results 1 to 11 of 11
  1. Hello all, my main video preview window works fine but the one on the bottom left is not ( you are supposed) to be able to view what the extras are etc.... by highlighting then clicking on the play button to see if it is something you want to keep or replace with a still. Thanks in advance for any help and please also reply to klbierley@bellsouth.net
  2. Look in the settings menus and make sure you have video preview enabled.
  3. Thanks, I will check that tonight and let everyone know. Kevin
  4. I had no luck finding exactly where the setting were pertaining to the video preview window. Thanks for the help. Kevin
  5. click edit menu, then preferences, then preview tab and check enable video and audio preview.
  6. Thanks, I had done that already even after a un-install and re-install ? I was thinking I must not have set someting else up correctly . everything else is working fine. But my video card is an older one. it is a Voodoo3 3dfx but it has always worked with no problems but perhaps that might be the problem ? . Thanks again and I look forward to any more suggestions as you know this feature would be very helpful. Kevin
  7. have you tried upgrading Direct X drivers? I think its up to 9.0c now. Could try upgrading drivers for the video card itself if any newer ones are available.
    Unfortunately I've never run into this exact problem and don't have much more insight to offer. Best thing to do would be visit the shrink website and ask on the forums about this.
  8. only_emo_kid
    Guest
    mine doesn't show the preview either.. hmmm
    Had the same problem. Solved by doing this. First select edit. Then select preferences and then the preview tab. Check the "enable audio and video preview" box. (I had already gotten to this step but it still didn't work). Then under "select Direct X video renderer", choose the option "built-in software renderer". After following this last step, the preview window on the lower left now works fine. Hope this works for you.
    wwaag
  10. Thanks all will try tonight and let you know
  11. Hey guy's all set works great and it is so nice to be able to get rid of all the preview. Thanks again, Kevin
  1. Replies: 2
    Last Post: 19th May 2010, 14:44
  2. Vegas Preview Window is choppy--please help!
    By duderdude2 in forum Editing
    Last Post: 24th Mar 2010, 14:29
  3. video window frame refresh not working
    By smithpgr in forum Capturing
    Last Post: 26th Nov 2009, 09:05
  4. No Video in Preview Window.
    By therearenorules in forum Capturing
    Last Post: 18th Jan 2009, 14:21
