VideoHelp.com Forum
  1. Since GSpot doesn't support Matroska, I'm not even sure what the audio format is.
    This particular file plays fine in Media Player Classic, but video only. It comes up with an error when trying to play it in MPC. Any help would be appreciated, as I'm not quite sure what I'm looking for.
    Stream 1
    Media Type 0:
    AM_MEDIA_TYPE:
    majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71}
    subtype: Unknown GUID Name {000000FF-0000-0010-8000-00AA00389B71}
    formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A}
    bFixedSizeSamples: 1
    bTemporalCompression: 0
    lSampleSize: 1
    cbFormat: 23
    WAVEFORMATEX:
    wFormatTag: 0x00ff
    nChannels: 2
    nSamplesPerSec: 44100
    nAvgBytesPerSec: 0
    nBlockAlign: 0
    wBitsPerSample: 0
    cbSize: 2 (extra bytes)
  2. Thanks - VideoInspector did the trick. Looks like its AAC.
  3. Media Player Classic has a built in AAC decoder, but if the audio stream is HE-AAC it probably won't play.
    If you install CoreAAC DirectShow filter, and disable the built in filter inside MPC (View / Options / Filters) the audio should be heard.
    CoreAAC seems to decode HE-AAC.
    CoreAAC directshow filter v1.0b9
  4. Member monzie's Avatar
    VLC / Videolan is all you need.
  1. No sound from matroska file with h264 audio.
    By anarchyx34 in forum ffmpegX general discussion
    Last Post: 29th Oct 2009, 14:33
  2. Replies: 0
    Last Post: 16th Aug 2008, 08:47
  3. GUI to convert Matroska (*.mkv) To AVI
    By qwerty9876543 in forum Linux
    Last Post: 17th Mar 2008, 21:38
  4. Searching for matroska/MKV Codec
    By moviebuff2 in forum Newbie / General discussions
    Last Post: 26th Dec 2007, 09:54
  5. Problem playing .mkv (matroska)
    By mk2006 in forum Newbie / General discussions
    Last Post: 18th Aug 2007, 04:33
