Hi, i am new, and i started burning today.
But with ritek dvd-rs 1-4x g04's
i make it so that the max is 4x, but it only goes to 2x,
what gives?
also i use dvd decrypt.
Results 1 to 12 of 12
Is your dvd burner set to DMA mode? It would help if you put in your computer specs. Here's a link on how to enable DMA in XP or WINDOWS 2000:Originally Posted by brymo
http://www.cdrlabs.com/phpBB/viewtopic.php?t=9668
http://www.cdrlabs.com/phpBB/viewtopic.php?t=7625
Yes i looked around and found stuff about this..
and i looked and it was already on..
any other ideas?
thanks
what is the exact media code on those RITEK G04? use dvd identifier to find out the exact media code and manufacturer. are you using a 80 pin cable for your dvd burner? some dvd burners don't work correctly using a 40 pin ide cable. it would really help if you put in your computer details which will be useful in trying to solve your problem.Originally Posted by brymo
it is on a laptopOriginally Posted by budz
toshiba p35-s609
but i think i just found the problem,
it was on mode DVD-RAM
so i just changed it, so i will see if this works now ( changed it to do cd/dvd) i never knew there was diff. modes
well it started to burn, but it just stops at 2x again
maybe i have to restart?
Are you using Roxio with the powerrec option? If so that's the optimal burn speed for that disc. It won't go any higher, it determines what's the fastest speed you should use for that disc. You can adjust it but I just let it do it's thing, no coasters yet!
I am fairly new to burning DVDs (done plenty of CDs) but isn't burning speed dependant on both Hardware & Media ?
My Burner will burn DVD - Rs up to X4 but only up to X2.4 with DVD - RWs
Yes but if you are using powerec on Roxio it examines the disc and picks the best speed regardless of it's stated speed. I would guess it won't exceed the speed. I've seen it record at different speeds on the same media, it depends on the disc.Originally Posted by Stewart
Nope, just normal nero/dvd decrypt.
And it just stops at 2x, and the dvd-rs are made for 1-4x
am i doing something small?
whats with this turining my hdd to DML?
or something?
i think i found the problem...
its the dvdr media, its the cheap ritek so i think thats it..
no biggie.. just have so many to burn when i first got it,.. but oh wells!
thanks for helping everyone
Ritek is a decent brand. When's the last time you cleaned your lens? That usually does the trick for me. You can get a cd lens cleaner for 5 to 10 bucks. It's a cd with a little brush on the bottom (usually on track 2).
this laptop is brand new, i called toshiba to ask if this is a known problem he said no..
and said it is probably the media.. like i thought
Burning to Hard Drive
By spacebiscuit in forum DVD RippingReplies: 8Last Post: 15th Dec 2011, 09:00 -
Drive Not Burning
By robburne in forum DVD & Blu-ray WritersReplies: 3Last Post: 19th Nov 2009, 19:57 -
burning to my hard drive
By hawks770 in forum Newbie / General discussionsReplies: 2Last Post: 10th Aug 2008, 00:25 -
Dvd drive burning very slowwww
By Soixante in forum DVD & Blu-ray WritersReplies: 13Last Post: 24th Dec 2007, 06:55 -
burning problem on new drive
By yogart in forum ComputerReplies: 16Last Post: 11th Jun 2007, 12:40
