Hi,
here is the infos given by gspot:
4CC : DX50/divx
xy : 656x368
Bitrate: 940 k/s
FPS: 25
Audio : 0x0055(MP3) ID'd as MPEG-1 Layer 3
128 kb/s (64/ch, stereo) CBR
44100 Hz
The player tries to play hit, then the front panel says "stop" and the player goes to the next divx on the disc
Any idea ?
Thx
Did you chck for GMC and Qpel ?
No I'm sorry. How do I check that ? And I thought it was only in xvid...
So if this is the case I need to reencode ?
Thank you
use this program to check and see if the file is encoded using QPEL and GMC.
if by chance it's not, that means the file has some kind of streaming error.
http://johnnys.nailed.org/avicheck.zip
Philips DVP5990 won't Play Entire AVI
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 10Last Post: 6th Feb 2012, 10:05 -
Philips DVDR3576H/37 - Burned Discs Won't Play in Xbox, PC DVD Drive
By jbd5010 in forum CapturingReplies: 18Last Post: 20th Mar 2011, 03:11 -
Philips DVP642 vs DVP3560 Which Player plays More File Types
By DJboutit in forum DVD & Blu-ray PlayersReplies: 4Last Post: 3rd Dec 2010, 14:39 -
Remote for Philips DVP642
By Melina in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jun 2010, 21:54 -
Philips 5140 won't play retail DVD
By areynaldos in forum DVD & Blu-ray PlayersReplies: 10Last Post: 26th Jan 2009, 19:46
