I am converting a tv show source at 960x528, 23fps, 275kbps, 700mb xvid to dvd. I use the highest setting on tmpgenc, with wizard I select dvd, 2 pass vbr, and under adv I select very high motion search, and keep aspect ratio. it makes about a 1.7gb mpg, I work with ac3 for audio. When I play back the video, when there is alot of movement or when people walk around a little, the video jumps a little and isn't smooth. Is it my codec? do I need to configure my codec for best quality? What am I doing wrong?
Results 1 to 9 of 9
Thread: Choppy video after conversion?
Your frame rate conversion is too low.....DVD standard is 29.97 fps for video. You are probably going to have to use the 2:3 pulldown option in TMPGENc to compensate.
"Hello. My name is Inigo Montoya. You killed my father. Prepare to die."
2:3 or 3:2 pulldown you mean? I did that with one and still was choppy
Not sure if your source is field based but I had a similar problem and found that I the wrong setting for the field order in TMPGenc (TFF or BFF)
how do you determine field order? doesn't tmpgenc do that automatically?
Try changing the field order.
If in doubt, Google it.
so on the wizard I should select interlace instead on non-interlace that shows up when I pick a file? then change field order?
well, I converted a small section of the video on a and b, but still jumpy, could it be my codec? I think I have the latest version, is there a better codec to play xvid?
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 06:25 -
Conversion problem - Laggy (choppy) video
By yaang in forum Video ConversionReplies: 3Last Post: 4th Nov 2009, 12:36 -
After conversion video is choppy
By 2112Video in forum Authoring (DVD)Replies: 1Last Post: 26th Aug 2009, 09:57 -
choppy audio from mpg to DVD conversion - Help
By Warhammerx in forum Video ConversionReplies: 4Last Post: 7th Dec 2008, 18:25 -
choppy video playback
By RobotFood in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 07:40
