VideoHelp.com Forum
  1. I encoded a few videos to MPEG2 (using the DVD NTSC option in TMPGenc) and when it got done encoding the videos, it had split the file into two seperate video and audio files. Why is it doing this? I've encoded vids before and this has not happened to me. Any suggestions? Thanks in advance
    Lisa, "Turn down the TV" "Honey if we didn't turn it down for the Cops, what chance do you have"-Homer Simpson
    Check your 'Stream Type' setting - it must be set to 'ES' (elementary streams), it should be set to 'System' to get a combined stream.
  3. Thanks for the quick reply, but where do I change this setting exactly, Thanks.
  4. Never mine, I see the setting. It is on system, but I'm going to try something.
  5. I just encoded another video under "System (Video+Audio) and it camw out only video and it didn't create a audio file. What's up? Thanks
  6. Ok, problem solved. The video I encoded didn't have audio to begin with. I encoded a video with audio and it worked. Thanks for the help!
  1. AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
    By arcooke in forum Newbie / General discussions
    Last Post: 5th Aug 2010, 14:18
  2. Replacing audio in MKV file without re-encoding?
    By 3560freak in forum Video Conversion
    Last Post: 2nd Mar 2009, 22:23
  3. re-encoding vid file for smaller size but keeping same format?
    By WidowMaker in forum Video Conversion
    Last Post: 28th Dec 2008, 13:56
  4. Replies: 3
    Last Post: 25th Nov 2007, 03:39
  5. Advice Request regarding TMPGEnc, File encoding, and DVD creation w/ Menus
    By Hal05154 in forum Newbie / General discussions
    Last Post: 25th Sep 2007, 13:13
