VideoHelp.com Forum
  1. Hello... I hope that some one can helpe me.... Every time I convert from a avi to mpge, with TMPGnc. Its stops at 97% doen, why cant I make it do the last 3%... HELP ME.....
  2. Member daamon's Avatar
    Hi chr_t1,
    It could well be a bad frame or frames. Use VirtualDub to scan for these. It can also be used to fix them (i.e. remove the offending audio and video).
    Hope that helps. Good luck...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Please try to post in the correct forum. I've moved this one for you.
  1. Tmpgnc doesn't work
    By better life in forum Authoring (VCD/SVCD)
    Last Post: 27th Nov 2008, 21:29
