VideoHelp.com Forum
  1. I wondered if someone could point me in the direction of a guide for this? I have done a search but cannot find one. In particular, I am after the correct quality setting to burn to DVD - normally I can only get upto 2 hours of DVD quality video on a DVD, but using my 8mm tapes I am sure I could get much more without losing any further quality.
    Thanks in advance.
  2. Member yoda313's Avatar
    Hello,
    You could use a smaller bitrater of 2500-3000. You can also use halfd1 resolution of 352x480 (ntsc). Use a video bitrate calculator found in the tools section to determine the rate needed for the length of time you want on the dvd.
    Of course you could also buy a dual layer burner and fit 8.5gb on it! (though they are far from perfect right now - and pricey blanks!)
    Kevin
  1. Replies: 7
    Last Post: 4th Apr 2012, 23:36
  2. Best way to convert analog 8mm tapes to digital
    By charliedog in forum Newbie / General discussions
    Last Post: 29th Nov 2011, 02:15
  3. Replies: 2
    Last Post: 11th Sep 2009, 17:27
  4. Can't transfer 8mm tapes to DVD-RW, advice please
    By nathanaa in forum Newbie / General discussions
    Last Post: 11th Dec 2008, 13:18
  5. copying standard 8mm tapes to DVD recorder
    By mjwhite in forum DVD & Blu-ray Recorders
    Last Post: 31st Dec 2007, 13:14
