VideoHelp.com Forum
  1. Member pchan's Avatar
    Visited my brother over the weekend. He just bought a Sony Video cam. He connected it to his PC via USB link. The bundle software only support capture video in VCD and direct burn to CDR.
    Is there any software that he can use to capture the video clip in DV format using USB link ?
    If not, any recommendation on the firewire card that support Sony's iLink.
    Thanks.
  2. Member daamon's Avatar
    Hi pchan,
    Any firewire card will do the job - even the cheap ones. Firewire is a universal standard and isn't limited to one brand.
    As for software, WinDV, AVI_IO, DVIO and Scenalyzer Live are regularly recommended in these forums.
    Firewire is commonly recommended over USB2.0 for DV transfer. For some reason, there are sometimes problems via USB2.0 but I've never known or heard of problems with firewire.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Originally Posted by pchan
    Sony cameras come only with USB cable. Get an 1394 cable (and 1394 card if not already installed).
    Just any $10 card will be good. Get those with 3 or 4 connectors. One day you will need more than just 2
  4. Member pchan's Avatar
    Thanks for the replies.
    It looks like firewire is THE option.
  1. Sony Video Hi-8 Editing Disk Lost. Need Free Capture/Edit Software
    By Classic '57 in forum Newbie / General discussions
    Last Post: 14th Jun 2010, 22:08
  2. Extracting Time Data from Mpeg2 Stream (Hard Disk Cam)
    By gallion311 in forum Video Conversion
    Last Post: 1st Dec 2008, 09:55
  3. Sony Video Capture 6 (Vegas MS) hard drive max size limit?
    By distendo in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 12th Jun 2008, 09:02
  4. Replies: 7
    Last Post: 12th Mar 2008, 14:05
  5. Recovery of formatted Hard disk Sony DVD Recorder
    By sparky10000 in forum DVD & Blu-ray Recorders
    Last Post: 1st Mar 2008, 15:47
