Hi there,
when encoding 2 movies into 1 with DVD RB the output usually ends up at 4.38 or 4.39GB, which is too big for DVD authoring program.
I use:
CCE 2.50 (with eclcce)
One pass vbr w/ analysis (This may somehow be the cause, I think)
Dynamically assign cell bitrates
VBR_bias=10
Quality_prec=24
eclPasses=2
The movies I encode are reauthored by DVD Shrink 3.2 without any compression and all audio bar primary 5.1ch AC3 audio stream removed. Start and end credits are trimmed off also.
Any ideas how I might get it to produce an output size of 4.2GB??
Thread: DVD Rebuilder oversized output
FIrst: One Pass VBR has a lot to do. Use just normal 2 pass VBR
By default RB output is 2236000 sectors (1 sector= 2048 bytes) which result in around 2.35 GB.
You can change this default by putting a CCETargetSectors=xxxxxxx setting in the Options area of the Rebuilder.ini file, where xxxxxxx are the number of sectors you want your output to be.
More details in the Rebuilder forum at doom9.org . At the Settings thread at the top of the forum, look for the Hidden settingsNewbie to DVD backup
Anyone ever use a transcoder on DVD-Rebuilder output?
By sldvd in forum EditingReplies: 2Last Post: 20th May 2010, 13:16 -
BD Rebuilder output files too small
By mpullar in forum Blu-ray RippingReplies: 9Last Post: 18th Mar 2010, 17:58 -
BD Rebuilder 1080 output
By HARRYSPADGE in forum Blu-ray RippingReplies: 8Last Post: 19th Dec 2009, 21:26 -
Strange BD Rebuilder problem - Output files too small??
By YBS1 in forum Blu-ray RippingReplies: 1Last Post: 19th Sep 2009, 19:20 -
DVD Video Image Oversized Question
By JerryRecords in forum Video ConversionReplies: 3Last Post: 21st Dec 2008, 11:14
Statistics
Newest guides
Latest tool updates
New media comments
