I just want the best quality xvcd that I can squeeze off my apex 660. If I am using 720x480 to start will the apex 660 work with xvcd 480x480 at bit rate of 2450?
I use 2520 bitrate on all my XVCD's and they play back fine.
Is there any experience using anything higher?
Also has anybody had success with 352x480 or 480x480 xvcd on apex 660?
threev,
I never did get this (352x480) to work well for VCD stuff (xVCD) - always gave
me the jitters or sound would chop-chop, bla, bla, bla.
But, with MPEG2 settings (xSVCD) of 352x480, quality is very good, but depending
on your source (AVI from captured satalete or dvd). Source has to be clean.
. . .or not (but requres a lot more work) You can check them out at my web site
down below.
I'm constantly updating it. Soon, I'll have it in frames for better
organization, but until I lean frames and its worth a visit.
And, they all play fine in both my Apex AD-500 and AD-1500 players.
Visit my WEB
site for some ( ATI-TV Wonder/PVR usb/Haup WinTV PCI/DC10+ ) Latest samples
* compare what you have with what I layed out for you all (guage)
I believe that these are a big improvement over the others I've
seen here at this site (for guaging)
well i use Sefy's XVCD and it plays great on my Apex and Pioneer
Yeah, but mine isn't XVCD, it's more like an xVCD, since the resolution is basicly a VCD, only using MPEG2 Compression to make more movie fit
I think the main diffrence between X(S)VCD and my own Se/Sx VCD formats is resolution, as most X are higher then VCD resolution and mine is specificly VCD settings with the only diffrence is the compression type (MPEG1 or 2 in VBR mode).
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Weird component problem with LG555 and Apex tv...
By dvd mon in forum DVD & Blu-ray PlayersReplies: 9Last Post: 3rd Jan 2011, 14:40 -
Crown ADVDR9000 (Apex DRX-9000 I Think...) Firmware.
By eufemia in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Apr 2009, 10:01 -
Replacement for Apex AD-1500
By siskiou in forum DVD & Blu-ray PlayersReplies: 7Last Post: 30th Mar 2008, 22:59 -
Apex AD1250X Owners?
By nemesys23 in forum Newbie / General discussionsReplies: 3Last Post: 1st Jan 2008, 17:36 -
Help! Apex 5131 Will Not Play DVD
By NautTboy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Dec 2007, 11:33
