VideoHelp.com Forum
  1. Hey guys, i have a Compaq DVD Player on my computer, and all of a sudden when I insert a DVD disc, my computer will not pick up that it is a DVD disc inside of the tray. I have install the latest version of ASPI for my drives, and it is STILL not working. Even went I open up a program to play my DVD, it says "no valid DVD drive/disc found". Can someone please help? THanks in advance.
    P.S. By the way i am trying to rip the .VOB files off of my DVD for back up purpose w/ DVD2SVCD
  2. Member fritzi93's Avatar
    Here's what I'd try, in this order:
    1) Use a lens cleaner on your DVD-ROM
    2) Defrag hard drive and reboot
    3) Right click My Computer> Properties> Hardware> Device Manager. Delete the DVD-ROM and the IDE controller it's on. Reboot and Windows will autodetect and reinstall.
    4) If problems started after installing something recently, uninstall it. For instance, having several burning apps increases the odds of compatibility problems.
    Good luck.
    P.S. Have you run aspichk.exe to see if your ASPI layer is working properly?
    Pull! Bang! Darn!
  1. Replies: 8
    Last Post: 15th Apr 2012, 10:23
  2. Replies: 10
    Last Post: 24th Sep 2008, 09:51
  3. New CPU:Video/Audio Encoding and DVD Authoring
    By Maikeru-sama in forum Computer
    Last Post: 29th Apr 2008, 13:56
  4. looking for low cpu usage video player.
    By eroy in forum Software Playing
    Last Post: 20th Feb 2008, 10:34
  5. CPU-Z reading for Intel Allendale cpu
    By budz in forum Computer
    Last Post: 8th Jul 2007, 19:33
